Supercharged 2008 Tbss 2wd
It hurts but it is time to let it go. I bought her brand new in September 2008 and have put 22k miles on it.
Mostly garage kept and I have only put 600 miles on since 2012.
List of mods,
Forged engine with Wiseco pistons and Eagle h beam rods,custom comp cam,Prc stage 2.5 ls6 heads and Arp head bolts. Ls7 lifters,Pcm of NC pickup tube and modded stock pan.
Tvs1900 with Innovators West overdrive crank pulley and full billet 8 rib belt setup. Has a 2.7
RIP pulley on the blower. Lc32 dual pass intercooler setup keeps intake temps in check.
Water pump pulley has been welded to the shaft as well.
Pcm of NC fender well intake w/ls7 maf.
Pcm of NC spal fan setup.
Walbro 450 fuel pump with full hot wire kit
Stainless works headers and non lmf true dual exhaust.
Transmission is a stage 3 build and has a Yank pro truck 3600 installed. Shifts perfectly
It is lowered with Tony's djm front kit and adjusted bags in the rear
Energy suspension front end links and bushings on the front bar and a djm rear bar with evilss2006's solid rear links. Suicide doors panhard bar.
Braided stainless brake lines front and rear
20x8 and 20x10 staggered wheels with 275 40 20 and 315 35 20 nitto nt05 tires.
Scott's front spoiler
Rear window handle delete
Red line tuning hood struts
Optima red top relocated the rear.
5k hid lows and fogs,led back up lamps
Lots more I can't think of right now.
The interior is in perfect shape. It has Tony's full led lighting kit.A few pieces have been color matched and it has a boost and afr gauge,other than that it is stock.
Outside has a couple of door dings and minor scratches from being daily driven when I first got it, over all probably a 9 out of 10.
The vehicle runs great and will burn rubber at highway speeds. Handles like it is on rails and can be steered with the throttle.
The bad is the engine oil had a tiny amount of bearing material in it when I changed it last.
It was just rebuilt with a new Gm crank and clevite bearings less than 300 miles ago so I don't know what to think. I do know I am done messing with it and don't care to figure it out.
It doesn't knock or make any other noises and will peg the oil pressure gauge under acceleration so I don't think it is serious.
Sold!
List of mods,
Sold!
