Thinkin about buying a boat
I was looking at something like the
Nordic Rage(25ft/600hp 502ci)
Nordic Heat(28ft/600hp 502ci)
www.nordicpowerboats.com (v-bottoms, open bow)
Any other idea's or suggestions from boaters?
Kinda new with this
Kinda new with this
Nordic does make a very good boat.. What ever you buy make sure it has a "Bravo 1" Or bigger outdrive. and also pull the plug on the bottom of the outdrive Looking for small metal shavings or water, when the plug is pulled the water will come out first. be sure it's the plug at the bottom of the case where the prop shaft is. Since your a performance truck guy you probably know about motors. but a new outdrive is $5000.00 bucks try to not get a bad one.. any other boat questions PM me, I have built boats all my life, I know a little..
I bought a 60's tri-hull with a Johnson 40hp beginning last summer for $350, sold it in september to a buddys friend for $450. They call it the rotton banana (it was an off/faded yellow)
I think this was the only known time in history a boat was sold for a profit!
Originally Posted by Brian@JPA
speaking from past experiance, a boat is nothing but a hole in the water that you dump money into
