Steel braided brake line
Old Feb 3, 2011 | 05:55 PM
Onetogofast's Avatar
Default Steel braided brake line
Odd question, I am using hard brake line to fix my fuel line on the Jeep. I had to cut out the flexable line from the factory and was wondering if one would be able to use steel braided brake line as the flexable section in the line to comp for motor movement from torque and jumping it. Thanks
Old Feb 4, 2011 | 01:18 PM
Can you run fuel threw braided brake line? I just need a cheap easy fix!!!
Old Feb 4, 2011 | 01:55 PM
Gadgetized's Avatar
I would just use fuel injected hose. That is about the cheapest fix you can do. If you used brake line you would still have to buy the ends, and that alone would cost more than the fuel injected hose.
Old Feb 4, 2011 | 07:01 PM
I already have a hand full of ends and fittings laying around and have most of it plumbed. The metal brake line I used for most of it has the threaded fittings still on it to use.
Old Feb 6, 2011 | 09:24 PM
Can you run fuel threw the flexible brake line?
Old Feb 6, 2011 | 09:44 PM
Gadgetized's Avatar
I don't believe there will be a problem. I would check with the manufacturer of the line to be sure though.
Steve-O-08
Apr 19, 2018 09:32 AM
mhorn0817
Mar 6, 2016 08:00 PM
fiatdale
Aug 26, 2015 09:05 AM
thewrx
Aug 12, 2015 08:28 PM
76k10chase
Jul 17, 2015 01:48 PM
