Started to open her up again :)
High on diesel fumes
I finally replaced my non-op methanol pump this past week and started running the meth injection again. Started to lay into it a bit to get the tune dialed in. Damn it feels good to be able to play again! This is the first time I've really been able to open up the Rex 408, and it feels great! I took a run from a dead stop tonight and got the tires to squeal a little bit coming off the line without any brake stall (which I have never been able to do), and by the time the turbo spooled up and I hit about 3500 RPM the tires started to break loose
They stopped spinning around 5500 RPM right before the 1-2 shift.
She's still running pretty rich and I'm only running 11.5* of timing up top for now. Boost controller is at it's lowest setting, which gives me about 9 psi at WOT. I can't wait to get the tune dialed in and start cranking up the boost
This is what I've been waiting for for about 8 months!! I'll see if I can get some video tomorrow or Sunday.
They stopped spinning around 5500 RPM right before the 1-2 shift.She's still running pretty rich and I'm only running 11.5* of timing up top for now. Boost controller is at it's lowest setting, which gives me about 9 psi at WOT. I can't wait to get the tune dialed in and start cranking up the boost
Engine is 9.4:1. Cam is a little small, but it's very street friendly and I have no desire to shift sky high in the RPM range. Right now I'm shifting around 5500-5700. Some of the detonation may be related to the oil in the take piping. I took the turbo in to have the seals replaced and the guy told me he didn't think there was anything wrong with it, but I have a feeling there is. Maybe once I get that cleared up the knocking will go away. The weird thing is that I can hear it but it never shows up on the scanner.
Adkoonerstrator
Yeah, I hear ya on the street friendly thing. I bet that is nice.
Definately get that oil cleaned up and maybe run some top engine cleaner through the engine too.
8psi on a 408 has gotta be pretty nice but, I bet 14psi is gonna be better.......anyone want to bet for real on that?
Oh yeah, what plugs are you running? Maybe step down to the next cooler plug and see if that helps any. Also, I wonder if it could be a backpressure issue in the exhaust.
Yeah a seafoam treatment might be in order. I'm trying to figure out if I need to run a breather setup and get rid of the PCV system. Then it might be time for a turbo rebuild.
I'm hoping for 10's this winter
