next 10sec(maybe 9 sec) ride
Old Jun 30, 2009 | 10:00 AM
  #51
TX Tahoe Z71's Avatar
Originally Posted by 4.8T
i wonder if the new edelbrock intake would fit under the hood. is that one have the 6.0l or the 6.2l?
6.0L, the G8 gets the 6.0 and the G8 GXP gets the 6.2. I read they only made about 1,800 GXP's before Pontiac went under
Old Jun 30, 2009 | 10:38 AM
  #52
TURBHOE's Avatar
so the edelbrock will bolt on the motor. it seems someone said it would fit under the cowl. that would be perfect, good power band and you can tap the manifold for the meth injectors.
Old Jun 30, 2009 | 04:14 PM
  #53
parish8's Avatar
single digit dreamer
it is a 6.0 but i guess it has the same heads. i will have to go try and find that intake. i like the idea of metal and 8 welded in injector bungs.
Old Jun 30, 2009 | 04:26 PM
  #54
TURBHOE's Avatar
i got the part number off of edelbrocks web site. its the xt ls manifold. then take that part number and type it in on froogle. i found it for less than $400.
Old Jun 30, 2009 | 04:33 PM
  #55
parish8's Avatar
soo that is just the typical carb style intake but for the l92 heads. hmm. price would add up by the time i got the stock fuel system hooked up and fuel rails and then a 2nd fuel system with rails and all that.
Old Jun 30, 2009 | 04:34 PM
  #56
TURBHOE's Avatar
no no, its the tunnel ram style with the 90mm inlet with 4 and 3 bolt flange.
https://www.performancetrucks.net/fo...d.php?t=443286
http://race-mart.storesecured.com/it...139-detail.htm the pic isn't right but the part number is.
http://www.edelbrock.com/automotive_...chevy-ls.shtml and link with vid.
Old Jun 30, 2009 | 04:36 PM
  #57
parish8's Avatar
aww ****. now that would be cool.
Old Jun 30, 2009 | 04:46 PM
  #58
TURBHOE's Avatar
now ya see the light!
Old Jun 30, 2009 | 04:47 PM
  #59
parish8's Avatar
i dont see where it says l92 heads
Old Jun 30, 2009 | 05:02 PM
  #60
TURBHOE's Avatar
i thought the 6.0 had the ls2 style heads.
never mind i guess its a 6.0l l76. well maybe trick can make an adapter for ya. whats the difference in the heads any way? is it the bolt pattern or distance or just the raised ports?
