It looks a lot easier than it is...
Old May 23, 2009 | 09:10 PM
2005 Silverado's Avatar
SPAM HUNTER
Oh...well not that it matters, but i used my swivel head, fine tooth snapon ratchet, with wiggle snap on plug socket on the back ones, and my 12 inch matco ratchet and snap on wiggle plug socket for the rest.
King you might want to get some better tools.
Dustin
EDIT: Roger is talking about a header extension. It slides over the plug allowing for a wrench to be used to break them loose. I have used one on some older trucks with headers, but not on mine since it still has stock mani's.
Old May 23, 2009 | 09:16 PM
GMCtrk's Avatar
changing the plugs is a piece of cake. The hardest part with headers is getting the #7 plug started when putting it back in....it's best achieved from the underside. Torque spec on the spark plugs is only 12 or 13 lb ft if I remember correctly...basically just snug and then 1/4th of a turn. Anti seize too.
Old May 23, 2009 | 09:44 PM
hirdlej's Avatar
Geez michael, with as many times as you've changed headers, changing spark plugs should be EASY for you..........
Old May 23, 2009 | 10:09 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
Originally Posted by KySilverado
I have to jack the truck up and change 2 of them, 5 and 8, from under the truck. Had to find a spark plug socket with a hex on the end of it to remove them with a wrench.
I'm about due for another set. Thanks for the reminder.
You're welcome
Originally Posted by SincalT/A
How did they look?
Make sure you used anti seize otherwise they b tight again.
They all looked great with only minor wear after ~1 year! Nice color too.
A dab of anti-seize on the threads and the boots. I had no problems getting them started. I tightened to snug and then a little extra for good luck
Old May 23, 2009 | 10:36 PM
lady3bglover's Avatar
Completely agree.. that #7 is a pain in the ****.
Old May 23, 2009 | 10:44 PM
PappyDan's Avatar
Tribe Shaman
damn i kick on the air compressor and break out my air tools.
just a click and a twist then squeeze the handel and it just comes right out.
replace is just as easy, stick the plug in to some 3/8 fuel line, stick in the hole,
and turn, tighten up and pop on my wire.
Old May 23, 2009 | 10:53 PM
Parke10's Avatar
the back 2 are the only ones that ever give me trouble even at that , it doesnt take me too long to change a set of plugs
Old May 23, 2009 | 11:15 PM
CHEVRACER83's Avatar
mines stock = EASY
Old May 23, 2009 | 11:56 PM
trever1t's Avatar
if they weren't so tight then it would have been a simple task but with the condenser, the steering shaft (i had to turn it so the nut wouldn't prevent the ratchet from fitting) the wiring harness was blocking #1 and some sensor wire i had to disconnect to get to it.
Old May 23, 2009 | 11:58 PM
SPAM HUNTER
Where you using a normal socket or a plug socket with a wiggle joint?
Dustin
