I'm SO F*CKING Stupid!
Old May 7, 2008 | 10:46 PM
Silverado_13's Avatar
Self proclaimed VILLAGE IDIOT
Default I'm SO F*CKING Stupid!
I left my house not 30 minutes ago just to get a coke and a pack of gum from QuikTrip..
Yeah, right! My luck fuc*ing sucks...
Came back home on a road that they're repaving and it's all loose gravel right now. Came around a banked turn quicker than I should have...
Spun. Completely backwards. Truck shut off. Went sideways into a curb. Both right side tires blew instantly. Rims on the wheels are gone...
Looks like I'm going to be buying new wheels and tires with my birthday money, whether I like it or not...
Anyone want to help me decide what wheels to get?
Anyway, here's the pictures that I was able to get...
Anyone have some wheels for sale?
Old May 7, 2008 | 10:51 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
Whoa!
I was going to say how the &*() did you manage to not even dent a fender....then I saw that last pic....oh man, that sucks big time, an expensive lesson. Good news is you didn't roll or get hurt.
Old May 7, 2008 | 10:54 PM
The thing that pisses me off the most is that these newer vehicles fuel pumps automatically shut off, my steering locked up, and my brakes were locked...
If none of that happened, I would have probably been able to save it.
It could have been a LOT worse however...
There was no traffic on this road... or cops. The truck didn't flip. I didn't hit a tree or a telephone pole. I'm walking under my own power and didn't end up in the hospital...
Old May 7, 2008 | 10:57 PM
2005 Silverado's Avatar
SPAM HUNTER
Well..like bill said...it could have been worse...glad to see your not hurt!
Dustin
TouchOfEvil04's Avatar
sucks but at least you didn't roll it. I mean damn man you were riding on slicks in the back basically.
Never heard of the fuel pump kicking off automatically though? Is this a fact or your guess?
Old May 7, 2008 | 10:59 PM
trever1t's Avatar
no crap...what causes the fuel pump cut off? I've never heard that before.
Old May 7, 2008 | 11:03 PM
From Wikipedia
Nowadays, the fuel pump is located inside of the fuel tank and is usually electric. The pump creates positive pressure in the fuel lines, pushing the gasoline to the engine. The higher gasoline pressure raises the boiling point. Placing the pump in the tank puts the component least likely to handle gasoline vapor well (the pump itself) farthest from the engine, submersed in cool liquid. Another benefit to placing the pump inside the tank is that it is less likely to start a fire. Though electrical components (such as a fuel pump) can spark and ignite fuel vapors, liquid fuel will not explode (see explosive limit) and therefore submerging the pump in the tank is one of the safest places to put it. In most cars, the fuel pump delivers a constant flow of gasoline to the engine; fuel not used is returned to the tank. This further reduces the chance of the fuel boiling, since it is never kept close to the hot engine for too long.
The electric fuel pump is generally on whenever the car's ignition switch is in the "on" position. The metering of the fuel into the engine is performed by the fuel injection or carburetor systems.
The ignition switch does not carry the power to the fuel pump, instead it activates a relay which will handle the higher current load. It is common for the fuel pump relay to become oxidized and cease functioning; this is much more common than the actual fuel pump failing. Modern engines utilize solid-state control which allows the fuel pressure to be controlled via pulse-width modulation of the pump voltage.[1] This increases the life of the pump, allows a smaller and lighter device to be used, and reduces electrical load and thereby fuel consumption.
Some cars with an electronic control unit have safety logic that will shut the electric fuel pump off even if the ignition is "on" if there is no oil pressure, either due to engine bearing damage or a non stalled engine, e.g. in a car accident. In case of an accident this will also prevent fuel leaking from any ruptured fuel line. Other cars have an additional roll over valve, that will shut off the fuel pump in case the car rolls over. Some Ford cars also have a fuel cut off switch that will simply shut power down to the electric fuel pump relay in the case of a collision.
The fuel sending unit assembly is the combination of the electric fuel pump, filter, and the electronic device used to measure the amount of fuel in the tank via a float attached to a sensor with sends data to the dash mounted fuel gauge.
Old May 7, 2008 | 11:10 PM
PappyDan's Avatar
Tribe Shaman
so how is that coke, still chewing the gum?
tire looked bald anyway.
un less you have a naked girl at the house that their was no need to leave
in the first place, slow down.
Old May 7, 2008 | 11:16 PM
pappy is speaking in cryptic talk again.
i actually understood just fine and agree.
Well, another reason I left is because I went to get my emissions testing done today and the check engine light came on. I don't know why I couldn't wait until tomorrow, just needed to see if the light was still on.
The coke flew out the window when I hit the curb and as a matter of fact I am chewing a piece of gum right now.
Yes, I learned my lesson the hard way. Yes, this sucks.
EDIT: And yes the tires are bald because I'm out of a job right now, I'm a high school student, and my parents don't just hand me money.
