I need recommendations for an epoxy floor.
Old May 13, 2009 | 09:41 PM
Spoolin's Avatar
GFYS and STFU
Hey lance, what's the best way to fix a chip in it? I lifted my 6K lbs truck with three jackstands about a month ago and one of the jackstands had narrow sharp base on it and it removed about one square inch of the coating, right down to the concrete. I was thinking about putting some Hydrualic cement over it but would rather put like an epoxy patch, do they have that?
Old May 13, 2009 | 09:49 PM
SimpleManLance's Avatar
these work great too, buy a set of these and use a cut off wheel and cut them down some so you dont twist your ankle ( beleive me)
here is me working on 10,000 sq ft of coatings
this is the profile your looking for to get a good bond.
me putting up 6" cove and putting down our trowel down system.
Old May 13, 2009 | 09:57 PM
KA41's Avatar
Thanks Lance, after reviewing several products, I am leaning towards the Wolverine Epoxy Floor System.
Old May 13, 2009 | 09:58 PM
im not to sure on what kind of epoxys are out there seeing as i only install one epoxy coating. (stonhardDOTcom) and they dont sell it to the general public. its the best stuff ive ever seen. and ive removed a lot of other epoxy coatings to put our stuff down.
back on track. i would look for the same stuff you got. that way you know it will bond to it self, or should anyways. the bad part is if its a 2 part your going to have to waste that whole mix for those little chips. i would check out the garage journal, im sure they have delt with repairing little chips better then i have, sorry.
Old May 13, 2009 | 10:02 PM
no problem. W.E.F.S. sounds like they make a good product. i remember reading a lot about them on the garage journal. how are you doing your prep?
Old May 14, 2009 | 12:34 AM
Spoolin's Avatar
GFYS and STFU
Originally Posted by SimpleManLance
...back on track. i would look for the same stuff you got. that way you know it will bond to it self, or should anyways. the bad part is if its a 2 part your going to have to waste that whole mix for those little chips. i would check out the garage journal, im sure they have delt with repairing little chips better then i have, sorry.
Yeah it was two-part which is why I'm not spending $80 just to fill a one square inch area. Thanks for the response though!
Old May 14, 2009 | 06:19 AM
KA41's Avatar
I plan on renting a floor grinder with a diamond wheel.
someotherguy
Oct 5, 2015 12:49 PM
Alco
Oct 4, 2015 06:58 AM
Wolftrk99
Oct 2, 2015 08:17 AM
Slammed silverado
Sep 15, 2015 11:50 AM
