Guys that have had air leaks
Old May 5, 2009 | 03:19 AM
  #21
lucky77's Avatar
Banned
having the same problem . . with my truck dude.. ever since the cam swap . . im getting a leak.. i keep getting code P1174 . .I'VE Checked everything.. and could not find anything.. does it throw a code at WOT?
Old May 5, 2009 | 07:11 PM
  #22
ForcedTQ's Avatar
Lightbulb
Originally Posted by 00ChevyScott
would a higher or lower number (0.300 or 0.900) be going lean?
Narrow band sensors are typically only accurate from .400V (15.0:1 AFR) through .800V (14.2:1 AFR). So a numerically lower number equals a higher air to fuel ratio.
Old May 5, 2009 | 09:56 PM
  #23
built408's Avatar
Lower the number, leaner it is. Once you get around the leak, the o2's should go to 0 or close to it.
Old May 6, 2009 | 01:18 AM
  #24
ForcedTQ's Avatar
Lightbulb
Yeah, that's what I just said two hours ago! They'll go to 0, but that number isn't accurate to use for tuning!
Bust out the wideband!!
Old May 6, 2009 | 09:28 AM
  #25
00ChevyScott's Avatar
Wearin' da big hat
I'm not trying to tune it... I'm trying to find an air leak
Old May 6, 2009 | 09:29 AM
  #26
BlackGMC's Avatar
Resident Retard
With the size of cam that he has IMO the wideband is useless at idle...
Old May 6, 2009 | 12:04 PM
  #27
BlackGMC's Avatar
Resident Retard
He just left my house, it is idleing like a champ now!
  #28
GMCtrk's Avatar
what was wrong?
Old May 6, 2009 | 12:25 PM
  #29
BlackGMC's Avatar
Resident Retard
Originally Posted by GMCtrk
what was wrong?
Decrease the Desired Airflow table, increased the idle areas on the MAF table, set the O2 switch points back to stock, increase the Startup Airflow Friction table, Decreased Startup Airflow Decay P/N and Gear, Increased Startup RPM Decay P/N and Gear, etc...
Old May 6, 2009 | 12:33 PM
  #30
Wearin' da big hat
Corey, you are THE MAN!
Drove it all the way home, parked it for a second, started right up perfect.
I owe you big time (again haha).
