Guy on Tech with the tool....
Old Apr 10, 2006 | 10:24 PM
FarmerBeau's Avatar
Sexy Party Mod
Originally Posted by white1
OK, water boils at 212*F is that better dumbass? Take some grease, and coat the outside of the pulley (I understand sometimes youre slow, thats why Im not typing fast) the part that slips into the front main seal. Take a torch (propane works fine, but map gas is faster) heat the INSIDE of the pulley (the part that actually touches the crank snout) evenly till the grease starts to melt and barely bubble. Grab the pulley (wear gloves Beau, it WILL be hot) and it should slide all the way on. Then all you need to do is thread the bolt in. The grease lets you know before you get it too hot, and it lubes the seal when you slide the pulley through the seal.
Haha. Smartass! Always gotta be a smartass! Good info though! Next time ill do it right.
Dude, you dont know how many times i have grabbed something i welded a minute prior with my bare hands. Youch!
Old Apr 10, 2006 | 11:13 PM
onebadrubi's Avatar
Hey farmer right after you weld metal its normally hot!
Old Apr 10, 2006 | 11:35 PM
kbracing96's Avatar
It's not hot, it heavy. That's why he puts it down so fast
Old Apr 10, 2006 | 11:46 PM
Coban's Avatar
Man we heated the **** outta that pulley but on the outside, I wouldnt have thought it would make that big of a difference.
Old Apr 11, 2006 | 06:59 AM
Fogle07's Avatar
Originally Posted by Flyer
Stuck the crank in the microwave?????
Did any sparks fly on that one?
yep. put it in there for like 10 minutes. checked it with the infared thermo thing till i thought it was hot enough to put on. no sparks or nothing. i did have a shop rag in there that caught on fire the first time i put the pulley on. i done it 3 times so it wont mess anything up. just dont use the microwave you plan on warming food up with of course
Old Apr 11, 2006 | 07:02 AM
white1's Avatar
Old Apr 11, 2006 | 08:37 AM
FarmerBeau's Avatar
Sexy Party Mod
Haha. Is that why?
Old Apr 11, 2006 | 08:59 AM
hellbents10's Avatar
LS1Tech Sponsor
I use heat on the pulley and n20 on the crank, works great.
Old Apr 11, 2006 | 10:51 AM
FarmerBeau's Avatar
Sexy Party Mod
We took a bottle of that Laptop cleaner (compressed CO2 in a can ) and turned it upside down and sprayed the crank snout on the last camswap on my truck. I still had to whop the **** out of it with a block of wood and a hammer....
Old Apr 11, 2006 | 11:29 AM
white1's Avatar
The cam swap I did Sat, I heated up the pulley, and it bottomen out like a well lubed..........never mind, but it went in...I mean on easy. I think my mind is somewhere else Ill be back.
