Any HVAC techs out there?
I'm trying to do the Humidistat to a Lennox G61 furnance. Anyway I'm not for sure how to do this. I know where the ODT sensor goes and H terminals go to water solenoid. What else do I need to do? I've 24 volts coming out of furnance but only when heat is requested. As soon as it shuts off the 24volts goes away. I think it needs a constant 24 but I'm not for sure where to get that. I'm sure the switched 24 needs a home too.
the control might need 24 volts, u can get 24 volts from the control board on the R and C terminals, Red being power and c being your common if that helps ya any, what terminals are on your humidistat?
This is in most cases true. But he has a two stage furnace. Really depends on how muc moisture he would like brought into the system. i cant seeing you needing that much moisture in the house.
