TrailBlazer SS Suspension | Wheels | Tires | Drivetrain |Engine | Body | News
TBSS E-Fan Kit???
Old Jun 28, 2009 | 04:03 AM
Question TBSS E-Fan Kit???
I just acquired an 08' Black fully loaded TBSS. Only 1,200mi on it.
I have been going through some posts, but have yet to find where to get an E-fan kit for the TBSS.
I've been away for a few years since I departed with my previous 05' VHO.
I'm now back thankfully.
I will be needing some advise on some simple bolt-ons that are worth the time and effort for my new ride.
I was really shocked to see a clutch fan set-up under the hood....I thought GM would be using e-fans on all of their vehicles by now.
Guess it was cheaper to use the manual fan.
Anyways, where can I acquire an E-fan kit and how hard or easy is it to perform?
Thanks,
Jim
Old Jun 29, 2009 | 12:07 AM
So...no one knows where to get this from?
Jim
Old Jun 29, 2009 | 11:23 AM
andrew383's Avatar
traveling mod
the 2 easiest options are the c6 and the ls1 fan swap.I currently have the c6 fan and will be changing to the ls1 fan for the ease of the fan opteration.
There have been some issues with the c6 fan not workin because of voltage fluctuation.
You can pickup ls1 fans usedfor pretty cheap and then most get the harness/bracket kit
from pcmforless
also there isnt to many tbss guys here most hang out at trailblazerssowners.com
Old Jun 30, 2009 | 12:55 AM
Cool man. Thanks for the heads up.
I use to be a very active member here a few years ago when I had my VMax.
I would prefer to be active here again, but it seems with very few TBSS owners here, it may not be so easy.
I'll still drop in from time to time I guess.
Jim
Old Jun 30, 2009 | 01:15 AM
from pcmforless
I assume you meant www.trailblazerss.com.
The one you posted does not exist.
Jim
Old Jun 30, 2009 | 01:36 AM
tbssowners dot com is prob what he meant
Old Jun 30, 2009 | 01:38 AM
RandomHero's Avatar
I did an ls1 efan install with Derek@edo's harness on a trailblazer a couple years ago.
Old Jun 30, 2009 | 06:01 AM
Tootall's Avatar
you can do a set of LS1 fans just fine . . . . the harnesses are easy to make.
Old Jun 30, 2009 | 09:03 AM
BICSS's Avatar
PCMFORLESS makes kits for both the C6 and LS1 fans. I think ADM performance and Tune Time also have kits. Most TBSS guys hang out at www.tbssowners.com, tons of info on this and many other mods.
Old Jun 30, 2009 | 10:46 AM
andrew383's Avatar
traveling mod
Jim
ya sorry had abrain fart there,its tbssowners.com
