TBSS air intake mods & E85
My TBSS had run 13.9's @ 98 mph with just a tune and K&N filter in the stock airbox. This week, I've changed some things around, and I'm heading up to PBIR tonight to test the difference.
I've replaced the K&N with a larger Race Parts Solutions filter and transition. (Nice set-up, still in the stock airbox.)
I've also taken a die gringer to the plastic behind the headlight, to let more cold air in.
And, I've retuned and switched over to E85.
I'll post up the results tomorrow
That is fantastic .....Do you recall what the DA was the last time you were at the track ? Check out what the DA was on the 2 different days and if the DA was similar both days then you have hit on a very nice low cost mod ...Congrats !
Is your TBSS a 2WD or AWD ?
60' was comparable both nights, so track prep wasn't a factor. The truck picked up less than 1 mph and 1/10 at half track, but pulled like a bad ****** on the long end, leading me to believe the bigger 4" inlet RPS air filter set-up and trimming behind the headlight are providing somewhat of a ram-air effect at higher speeds. I was very happy to see almost 2 full seconds and over 2 mph improvement in the 1/4 mile.
The e85 might also be helping; I just changed all the cells in the Stoich table to the e85 value, and added 2* timing across the board (figuring I could safely get away with that due to the higher octane) from my old gas tune. However, its leaner than I'd like it to be with the stock injectors going static on the top end. Basically, I don't have enough fuel to make any more power, but I may try putting together a home made electric fan kit to put more of the power I've already got to the ground. Between that, and maybe removing the heavy spare tire and disconnecting the front swaybar, I might be able to put this pig into the 13.5's with under $100 total investment. (Truck is 2wd.)
Although I still haven't modified the VE tables, nor scaled the MAF, the Race Part Solutions TBSS laid down a 13.429 @ 102.06 mph tonight at PBIR. Mods are just our RPS TBSS air filter kit, thermostat, and hacked together e85 conversion. Once I get the tune dialed in and swap this power robbing belt driven fan for our new e-fan set-up, this thing is going to fly
If you want to check and see if your headlight mod is working , take out the passender side headlight and run it down the track that way ...alot of guy's with tbss's run them at the track that way to see if there is an issue with good ram air and I think you will find some additional power ! Good luck and great times
