TrailBlazer SS Suspension | Wheels | Tires | Drivetrain |Engine | Body | News
Question on TBSS TPS%
Old Sep 28, 2006 | 07:43 AM
ridnlow's Avatar
Default Question on TBSS TPS%
Got my hp tuners in yesterday and did some logging on my buddies 06 Trailblazer SS.. at WOT im only showing 83% TPS.. i looked at all the tables i thought corresponded to that and they all showed that it could go to 100% at some point... Is there something in the tune i can adjust or is this something to do with the actual throttle body??
Old Sep 28, 2006 | 12:43 PM
TchargedLS1TA's Avatar
I noticed the same when doing mine. I think it has something to do with the torque management at low-rpm
Old Oct 11, 2006 | 04:02 AM
skinnies's Avatar
10 Second Club
This is normal from everything I've seen.
Old Oct 11, 2006 | 07:51 AM
leftcoast32's Avatar
FormerVendor
You can go in and log ETC% which will show 100%. The TPS% is just an output voltage the computer commands to fully open the throttle blade. When you convert to the C6/GTO/Z06 throttle body then you will need a full 88% TPS to move the blade completely. The blade will actually only miss a few degrees of movement at the 83% TPS output. Even with the blade not opening completely at 83% TPS we found that my SSR with the upgraded throttle body was flowing more air.
maxspeed05V
Aug 26, 2015 04:21 AM
smokeshow
Aug 23, 2015 08:23 PM
Bluchevypick
Aug 18, 2015 09:11 AM
maxspeed05V
Aug 17, 2015 08:41 PM
USMCvet0311
Aug 1, 2015 07:45 AM
