TrailBlazer SS Suspension | Wheels | Tires | Drivetrain |Engine | Body | News
Can 6.0 handle dry no2
Old Oct 8, 2008 | 03:57 PM
mano3's Avatar
Default Can 6.0 handle dry no2
I just purchased an 08 TBSS. How much no2(dry kit) can the 6.0 handle safely....... If there is a safely. One more question. What is the best CAI for these?
Old Oct 8, 2008 | 04:30 PM
sickREDsierra's Avatar
i like a 150 dry, just have it dyno tuned while you spray... make sure you have the right A/FR.
Old Oct 9, 2008 | 07:42 PM
andrew383's Avatar
traveling mod
id say 100-125 just to be safe
i run the ieatsrt8 cai,but ADM also makes a good 100mm setup as well.
dont go with the k&n or the airaid as there open to the engine bay
Old Nov 15, 2008 | 06:37 PM
Be careful as I tried running a dry system but the nitrous keep freezing the MAF due to the short intake.
Old Nov 15, 2008 | 07:23 PM
childers86's Avatar
so my K&N is bad for a dry shot?
Old Nov 15, 2008 | 09:27 PM
andrew383's Avatar
traveling mod
do you have a tbss?
Old Nov 16, 2008 | 12:59 PM
05RST2NV's Avatar
Dont waste your time with a dry kit. You will be disappointed. Run a wet kit, its safer and hits much harder..
Old Nov 16, 2008 | 01:31 PM
parish8's Avatar
single digit dreamer
there are diferent ways to do a dry kit. most of the time when someone says dry kit they are planing on just spraying thru the maf. for me this didn't work well at all. my a/f ratios were all over the place and i got codes from freezing the maf.
i think a properly done dry kit (not thru the maf) is safer and there is no reason why a wet would hit harder then a dry if the nozles are at the same place. i have seen kits where they add pulse width to your injectors when the dry kit hits. that is the best way to do things rather than trying to put fuel thru the stock intake.
that being said i simple wet kit works great as long as you have the safety stuff like wot switch and window switch. wet is what most people around here use.
Old Jan 26, 2009 | 11:22 PM
mano3's Avatar
Default Dry NO2
Thanks guys!
The reason for the question is I have a dry kit I took off our old 97 Z28(LT1) It worked great on this car. It had a best time of 7.40s in the 1/8 mile all stock except for gears and the car was convertable (heavy 3795lbs). The kit has a Nitrous pressure regulators that connects to vac lines to adjust fuel pressure. I was hopping this would work on the TBSS.
cheyenne383
Nov 13, 2015 09:24 AM
smok'nZ
Oct 6, 2015 01:14 PM
turbo6c3
Oct 5, 2015 06:11 PM
BCraven1018
Oct 1, 2015 08:22 PM
JoshH
Sep 28, 2015 11:19 AM
