TOWING & OFFROAD PERFORMANCE Towing |Suspension | Wheels | Tires | Drivetrain |where the pavement ends.
Yukon XL leveling..any tips?
Old Mar 31, 2006 | 12:57 PM
Revelation222's Avatar
Originally Posted by jephs422
Mine has trailing arms....
Oh, hehe. My bad. Geuss I should of read your SIG
How much do you think you need to raise the back? And would that be before or after the 1.5 key in the front?
Old Mar 31, 2006 | 03:59 PM
jephs422's Avatar
Well I really don't need to raise the rear I guess. My main concern is fitting the largest tire I can on there. I do a LOT of offroading, so it's not for show. And since I can't afford a lift right now, every few inches helps. By the way, what is the largest tire I'd be able to run with another 1-1/2 in the front. And what's the max out back.
Old Apr 1, 2006 | 08:20 AM
MonteCarlo31's Avatar
You need to be careful, you have a 1/2 ton Yukon, which may or may not have the suspension leveling system. If you start moving the front end hight you may end up with problems such as the rear trying to raise high to level but maxing out. If you have the autoride with leveling you'll need to do some research into lifting it.
Old Apr 8, 2006 | 12:38 AM
jephs422's Avatar
So I think I'm gonna go ahead and get a set of Ford keys. I'm running 285/70/16's right now, or 75's I don't remember. But they're just under 33 tall. If I get 1-1/2" of lift, can I go up to a little bigger? Or am I maxed out?
calsdad
Jun 14, 2023 11:07 PM
Miguel199
Oct 16, 2015 08:04 PM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
97_ek
Sep 23, 2015 09:16 PM
2500ZL1
Sep 12, 2015 03:50 PM
