TOWING & OFFROAD PERFORMANCE Towing |Suspension | Wheels | Tires | Drivetrain |where the pavement ends.
XR258HR cam
Old Feb 15, 2011 | 08:34 AM
Rjaimw's Avatar
Registered User
Default XR258HR cam
This comP cam says it has great torque for towing and RV's . Is anyone using this? I have an 8.1 w/ 35s and 3.73 I already have the exhaust and intake taken care of and i have a nelson tune now I need a cam but not sure what to get jus lookn for some tiremspinning torque fo the mud
Old Feb 15, 2011 | 01:48 PM
andrew383's Avatar
traveling mod
That is a fairly small cam for that motor but would help either way..I would say step up to the 264,212/216??
Have you thought about a gear swap???
Old Feb 15, 2011 | 04:31 PM
dmelvin's Avatar
Seems like a real small cam for a 8.1, I'd look at the one Andrew mentioned. there are guys running that one in 5.3's and seeing little or no loss on the low end with no torque converter, so I would expect you to lose none, and maybe even pick a little up on the low end.
Old Feb 15, 2011 | 09:10 PM
southern_chevy's Avatar
yea I dd that cam in a 5.3 tops out about 6k could only imagine it in a 8.1
Old Feb 17, 2011 | 08:16 AM
Rjaimw's Avatar
Registered User
Lol 6k I hope I never have to get to 6k in the mud... Would I have to change out my springs on the 264 cam? Yeah Im thinkn bout the gears but not sure yet. Dnt want to get my mpg under 6. I get 8mpg rt now. Ive heard about a "double overdrive" that u add to ur transmission but dnt know much about it
Old Feb 17, 2011 | 08:28 AM
dmelvin's Avatar
You do have to change springs, I'm gonna go with the bigger brother of the 264, and I'm going to use the LS6 "yellow" springs that are on the heads I'm going to use. You can pick up a set of those for cheap... like 60-70 bucks.
Old Feb 17, 2011 | 09:37 AM
andrew383's Avatar
traveling mod
Yes it would be best to change springs..
35's with 3.73's is killin the mpg..If you stepped up to a 4.30 or even 4.56 it would help performance mpg..
Old Feb 17, 2011 | 11:30 AM
Rjaimw's Avatar
Registered User
Oh really ? I have never messed with gears im gonna see how hard it will be.. U guys are alota help
Old Feb 17, 2011 | 01:22 PM
andrew383's Avatar
traveling mod
Well having bigger tires puts the rpm lower but being to low can make the engine work harder and thus using more fuel..Bringing the rpm back up will put it in the better power band..
I had 285/70/17's on my truck shortly after i bought it and didnt like how it pulled my trailer..So i went down to a 255/75/17 and amount of power it had after the swap was amazing..
Im still debating on going to 4.10 or 4.30 myself
Old Feb 17, 2011 | 05:01 PM
Rjaimw's Avatar
Registered User
Ok now Im going with the gears 1st but now I dnt know what type of differentials I have.. I have a 14 bolt in back I think its a 10.5?? Or can it be a 11.5?? And I have a 12 bolt in front I think its a 9.25... Im thinkn about 4.56 gears but can go with 4.88 according to the charts Ive seen. Anyone got any info???
