TOWING & OFFROAD PERFORMANCE Towing |Suspension | Wheels | Tires | Drivetrain |where the pavement ends.
torsion key question???
Old Dec 28, 2005 | 10:49 AM
say'n somthin's Avatar
Hi; On the same topic, once you have the keys, how much can you crank the torsion bars. I just cranked the stock torsion bars and got the same lift as a friend who just put the keys in. But if I put the keys in and can crank the bars, I might be able to get more lift as well as 315's on 16' rim. Can anyone advise? I have an 03 2500 HD.
Old Dec 30, 2005 | 09:00 AM
I wouldn't go more than 2" above stock height...any more and you are asking for problems w/ your CVs and balljoints.JMO.
Some trucks can get more lift out of the stock keys than others...I got maybe 1.25" out of maxxing mine (6 turns), but some get closer to 2". I would only use diff. keys if I couldn't get 2" out of the stockers.
Old Dec 30, 2005 | 09:26 AM
NoChrome's Avatar
Even if you can get that extra 2" out of your keys, your shocks dont have the travel to support it.
Old Dec 30, 2005 | 04:32 PM
TIM Z's Avatar
11 sec. Truck Mod
on my z71 i maxed the torsion bars out and raised 1-1/2", i d like a nother 1" also.you must be the smartest ford tech there is, you drive a chevy to work!
Old Dec 31, 2005 | 03:11 PM
If I did install the keys, I am guessing that I only need another inch if that to fit the 315's. Between the tires, the T-bars, and the 2" rear blocks I got over 3.5" of lift on the stock shocks. If I could install the keys with the tbars cranked app 1" the 315's and bigger rear blocks, I could get close to 6" of lift. I would most likely have to change the shocks. However, I have heard about the CV's, Balljoints, and the Drive-shaft angles. So I don't know. I just need that 1 more inch in the front and I think I would be good. I might consult my local 4WD shop and try it.
Old Dec 31, 2005 | 05:54 PM
NoChrome's Avatar
I know with all the 6in "kits" hey have spacers that make the cv's longer.
Old Dec 31, 2005 | 06:32 PM
GatorFan's Avatar
Default Ford Keys in my Sierra
Hey fellas,
I put the Ford keys in mine 00 Sierra 4X4 and was wondering where to buy the blocks to lift the rear. I actually had to lower my TBs a little to equal out the front and rear end. It looked like my truck was hauling something heavy in the rear and was awful looking so I just lowered the bars down to get that level appearance again. Those keys lifted mine almost 2.5" in the front. I am running 285 Pro Comps right now but wouldn't mind throwing 315s on it as well. I already have Pro Comp ES3000 shocks, but I don't know if they would extend that far if I lifted it back up. I would like to lift it back up to the original height when I put the Ford keys in it.
Thanks
Old Dec 31, 2005 | 06:42 PM
jays99 VRO's Avatar
doing only the keys is pretty much a half a$$ job...when its cranked up that far your ruining your shocks because they are not long enough and they bottom out...the factory bump stop hits way to early and its almost impossible to do a proper alignment...i looked into it and found a company called cognito motorsports and they sell a well engineered leveling kit... http://www.cognitomotorsports.com/01...ing_system.htm thats there site and this is a nice write up on the kit http://www.off-road.com/chevy/projec...nito_levelkit/
Old Dec 31, 2005 | 08:42 PM
Hey GatorFan - You can get those blocks almost anywhere. You will have to get longer u-bolts because of the blocks. I got mine from the local 4WD shop. But try any of your parts shop around you and they should be able to help, or you can try Summit Racing. I had the same rear-end sag so that is why I put the blocks in. If you need the length of the u-bolts let me know and I can try to find the dimensions. As far as it being a half-A** job, I have been running my setup for 56000 miles and did the same on three different HDs w/o any problems. However, as Jays99 VRO states there probably is a more effiecient way. I am not going to quit until I get those 315's to fit.
Happy New Years guys. I enjoy browsing the threads and listening/reading all your constructive help. Thanks Ted
maxspeed05V
Nov 11, 2015 04:20 PM
iregret
Sep 10, 2015 09:00 PM
USMCvet0311
Aug 1, 2015 07:45 AM
Kaldar
Jul 27, 2015 06:42 PM
signguy62
Jul 25, 2015 03:12 PM
