TOWING & OFFROAD PERFORMANCE Towing |Suspension | Wheels | Tires | Drivetrain |where the pavement ends.
are these worth it?
Old Oct 23, 2007 | 05:05 PM
southern98ta's Avatar
Default are these worth it?
i just wanted a lil more lift out of my truck. nothing crazy just to make it have a better stance.
http://cgi.ebay.com/ebaymotors/99-06...spagenameZWDVW
Old Oct 23, 2007 | 05:19 PM
Chevy Cowboy's Avatar
Piss Pumps for Sale
From: Moncton, New Brunswick, Canada, The True North Strong and Free!
well th link isnt working for me but Im pretty sure there just super overpriced keys for the torsion bars, if your going that way, just drop by your ford dealer get some ford torsion bar keys for 50 bucks and you'll get the same results
Old Oct 23, 2007 | 05:39 PM
nightrunner's Avatar
Mr. Obvious
Originally Posted by ebay listing
You are bidding on a 2" lift kit for a Tahoe, Yukon, Avalanche, GMC, Escalade, Denali, Suburban, H2, ½ ton Silverado model trucks, 99-06 torsion bar ONLY (2"-2-1/2" front and 2" rear). The kit contains a new pair of forged torsion bar adjusting cams, 2" steel lift block (NOT aluminum extruded), u-bolts (10-1/2" Lg inside) for rear leaf springs and a set of instruction.
all this for $150
all it is is tbar keys and rear lift blocks, which i think 4x4s have stock
Old Oct 23, 2007 | 07:19 PM
Yeah, those blocks are useless for your truck...you already have 2" blocks from the factory. Go to the Ford dealer, get the keys for a '97-'03 F-150 for $50. Then get either a 3" or 4" block or an AAL (add-a-leaf) for the rear if it needs it and you'll be set.
Old Oct 23, 2007 | 07:57 PM
hard2kill's Avatar
just crank ur stock tbars 5 turns i did got a solid 1.5in. lift exactly half in. lower in the front then the rear and im not maxed out and it was free
Old Oct 23, 2007 | 08:27 PM
StrokerAce03's Avatar
Funny thing is that is says it works for the SUV's which have coils in the rear so blocks would be useless. I concur with everybody else; get some Ford keys for $50 from the dealer and an AAL for the rear. If you wanted to go all out you can replace the stock torsion bars with the 1 ton GK bars; that'd give you about an inch or so and won't sag like the half ton bars will.
Old Oct 23, 2007 | 08:58 PM
BlownHD's Avatar
Thats all I did, plus got shock extension brackets. Crank the factory keys, if you install reindexed keys you will most likely need longer front shocks or extended brackets. Plus you might be at bad angles for everything else. Bring the front up first, then decide if you want to lift the back. If you don't want to change the ride quality out back get Offroad Design's 1" zero rate AAls. They are pretty much a one inch block that bolts into the leaf pack.
Old Oct 23, 2007 | 09:27 PM
Onetogofast's Avatar
All I can say is "Covered Chuck Wagon", my was very stiff in the front.
Old Oct 24, 2007 | 03:59 PM
i searched and saw you can get 2" out of ford keys. will that put the truck level or will i need to get a add a leaf. who sells add a leaf
Old Oct 24, 2007 | 04:50 PM
hard2kill's Avatar
u can get almost 3in with ford keys i can get level or higher in the front with stock keys there are lots of aal's try 4wheelparts.com or rockymountainsusp.com
