Swapping rearends. Disc to drum
There is a little piece called a residual pressure valve that keeps the pistons out so the brakes work right away. As the springs on the drum system are much stronger than the seal on the caliper, the system maintains more pressure for the drums. If you don't change the master cylinder, your brakes will be dragging all the time, performance and mileage suffer, and pad life will be short. Swap it out and life is good!
A quick follow up as I am looking to do the same thing, I have an '05 Silverado with 3.23 open rear end with Drums and I want to put my 3.42 G80 axle with Disc in its place.
Sounds like besides just the basics stuff I need/should also swap the master cyl and I would be golden? No other valves to swap as the master Cyl is what has the correct proportioning valve in it?
Corvette454l88
Sep 1, 2016 01:24 AM
mrgrim
Jul 8, 2015 08:12 AM
