TOWING & OFFROAD PERFORMANCE Towing |Suspension | Wheels | Tires | Drivetrain |where the pavement ends.
Swapping rearends. Disc to drum
Old Jun 26, 2015 | 08:29 PM
TrickTurbo's Avatar
Truck Sponsor
Default Swapping rearends. Disc to drum
I am going to swap out the rearend in my 03.
Disc over drums.
Do I need to do anything to the brake system for this swap.
Proportional valve?
Old Jun 27, 2015 | 09:54 AM
1FastBrick's Avatar
Custm2500's Rude Friend
Not if your swaping the whole rear. but the master cylinder is different between 4 wheel disc and a disc/drum set up.
Old Jun 29, 2015 | 07:34 AM
Tigger Welder's Avatar
There is a little piece called a residual pressure valve that keeps the pistons out so the brakes work right away. As the springs on the drum system are much stronger than the seal on the caliper, the system maintains more pressure for the drums. If you don't change the master cylinder, your brakes will be dragging all the time, performance and mileage suffer, and pad life will be short. Swap it out and life is good!
Old Aug 13, 2015 | 12:07 AM
thelostartof's Avatar
A quick follow up as I am looking to do the same thing, I have an '05 Silverado with 3.23 open rear end with Drums and I want to put my 3.42 G80 axle with Disc in its place.
Sounds like besides just the basics stuff I need/should also swap the master cyl and I would be golden? No other valves to swap as the master Cyl is what has the correct proportioning valve in it?
Old Aug 13, 2015 | 01:06 AM
1bad2k's Avatar
Awesome! I was wondering for a while what kept that extra pressure on the rear brakes since I want to swap mine to discs. I've already done hydroboost and used the master cylinder it came with from a disc brake truck....looks like I'm good to go!
Bluecollar Hotrods
Jun 11, 2024 11:37 PM
Corvette454l88
Sep 1, 2016 01:24 AM
chopperloco
Jul 10, 2016 10:45 PM
jrplz
Jul 9, 2015 12:07 AM
mrgrim
Jul 8, 2015 08:12 AM
