TOWING & OFFROAD PERFORMANCE Towing |Suspension | Wheels | Tires | Drivetrain |where the pavement ends.
? regarding rim size & axle replacement
Old 06-23-2016, 05:22 PM
Registered User
mongoss's Avatar
Default ? regarding rim size & axle replacement
Currently own a 03 Silverado z-71 with a 3 inch body lift & 16" Mickey Thompson Classic rims with 285-70-16 General Grabber AT2's.
Have the stock rear axle but have been looking to upgrade it with a 14 bolt AXN axle. Been reading a lot here on how to do this and all that is necessary in making this all work.
My ??? is if I install this axle on my truck will the 16" rims still fit with the caliper being slightly moved from its current location or will I need to go to a larger rim Diameter????
Thanks
Old 06-25-2016, 03:21 AM
BlueTexan24's Avatar
It would be easier and most likely cheaper to put a good posi in the 10 bolt IMO. They can be made strong with a tru trac differential.
weeble1
06-02-2016 08:35 AM
nathanstowing
06-01-2016 06:04 PM
parks450
05-29-2016 10:07 AM
flatblack83
05-28-2016 09:06 PM
lxcoupe
05-27-2016 09:02 PM
Quick Reply: ? regarding rim size & axle replacement
