need help finding 8.6 c-clip elim kit
hey everyone, after my trucks rear end letting loose last night im trying to gather a list of parts to get this thing back on the road. i found a moser spool for 187 bucks, hopefully my ring and pinion are still covered under warranty but my biggest dilemma is finding the correct c clip eliminator kit. ive tried finding the specs on the axle shaft diameter but havnt come back with any results. ive found a few c clip eliminator kits through summit but i cant find one that works with the 8.6. if anyone could help point me in the right direction it would be greatley appreciated!
thanks
tj
thanks
tj
I don't believe there is one for the truck 8.6 diff. I think you'll have to cut the tube ends off, and weld new ends on that accept the C-clip elim kit. IIRC, you'll need custom axle shafts too.
diameter of the shafts are different? on yukons website theyve got a 30 spline spool that says it works with the 8.5 and 8.6 theres gotta be something compatable. on summit they do have one that says will work with 10bolt/12bolt as long as theyre not drum brakes. please correct me if im wrong but if i go with a mini spool i dont need the clip elim kit correct? thinking mabey ill just go get an open carrier from the junkyard put in the mini spool/ set up the ring and pinion and hopefully be good to go
You would have to do something custom for the trucks and you would probably need to change the brake setup.
I looked into building this before and its very complicated to retain full use of the factory brake package.
seems like a lot of work just to run a full spool, mabey im just better off throwing a open carrier with a mini spool in then. i thought about grabbing another g80 from the junk yard but id rather just take the time and money do it once and do it right
