leaf spring poly bushings.
Check out the PerformanceTrucks Tire/Rim Calculator
Towing |Suspension | Wheels | Tires | Drivetrain |where the pavement ends.
May 2, 2010 | 05:37 PM
sierra69
Jun 2009
flagstaff,az
will i be doing any good to put poly leaf spring bushings to help traction a little?
sierra69
Find More Posts by sierra69
May 3, 2010 | 01:37 AM
BadAssChevy327
Aug 2005
Ocala, Fl
the less play the better. where did you find these poly bushings?
BadAssChevy327
Find More Posts by BadAssChevy327
May 3, 2010 | 10:53 AM
tallChevy
Jul 2008
Douglas Georgia
only if you have wheel hop and the bushings are worn. I would just get some bars. changing those bushings will be a pain and might not even work.
tallChevy
Find More Posts by tallChevy
May 3, 2010 | 11:33 AM
andrew383
traveling mod
Oct 2007
so. indiana/texas
Changing them out could be a PITA,but like stated above the gain wouldnt be worth the effort IMO..
andrew383
Find More Posts by andrew383
May 3, 2010 | 12:30 PM
Dewey
Dec 2008
Huntsville, AL
FWIW you can get them from LMC Truck
Dewey
Find More Posts by Dewey
May 3, 2010 | 04:04 PM
sierra69
Jun 2009
flagstaff,az
I found them at a local 4x4 shop.but i took them back because they do look like a pain to do and who sells traction bars for my 2007 n/b 4x2?
sierra69
May 3, 2010 | 07:25 PM
tallChevy
Jul 2008
Douglas Georgia
it is not that they look like a pita, they are ask anyone with caltracs
Boosted 4.8 LS
60-130 Dragy runs?
Aluminum intake gaskets
Left Power Door Mirror Position Detent Not Holding 2005 Silverado
Local fastest NA street.
24
1.5k
tallChevy
May 3, 2010 | 07:49 PM
Dewey
Dec 2008
Huntsville, AL
or anyone that's replaced leaf-springs
Dewey
.660 lift dual springs with Ti retainers
1989k1500
05:16 AM
2001 GM 2500 - Complete IFS, 14 Bolt Rear, T-Case, Driveshaft
ice17
05:18 PM
Mcgauphys strut bushing crushed
vmaxpro
06:46 PM
.6XX+" lift springs on stock cam?
zblee
Sep 19, 2015
06:33 PM
Moog Offset bushings
xerox17
01:23 PM
Tags
al
az
bushing
bushings
c1500
flagstaff
huntsville
leaf
leafs
leafspring
poly
spring
springs
stock
work
Back to Subforum
View Next Unread
I wanna LIft
08:30 PM
