TOWING & OFFROAD PERFORMANCE Towing |Suspension | Wheels | Tires | Drivetrain |where the pavement ends.
How much lift?
Old Dec 24, 2006 | 11:27 AM
  #61
Country Boy's Avatar
Senior Member
What is the "trimming" that people talk about? What are you trimming?
Old Dec 24, 2006 | 12:53 PM
  #62
ramair383ci's Avatar
Depending on the size of the tires or the offset of the wheel will also depend on what you trim. In my case I would have to trim the front bottom corner of the bumper in other cases the air dam if your truck is equiped with one. Since I'm going pretty big I also have to trim the bottom of the back fender, a little bit of sheet metal between the lip of the fender and where you would mount the nerf bars or running boards. Hope this helps.
Old Dec 24, 2006 | 12:55 PM
  #63
Senior Member
So you actually have to trim metal panels. my 04 has the front air dam. Interesting.
Old Dec 24, 2006 | 01:08 PM
  #64
Well like I said I do because I'm going to be running 36x15.5x20 on a 10 inch wheel with a 25mm offset. I have a 6 inch lift or 4-3/4" some say with ford keys so in order to tuck does baby's in those fenders I have to do some trimming. In my case the trimming will not be seen because I'm planning on putting some bushwaker pocket fenders.
00loudchevy
Dec 3, 2015 05:54 PM
Jake75
Oct 2, 2015 02:28 PM
JoshH
Sep 28, 2015 11:19 AM
vmaxpro
Sep 28, 2015 11:10 AM
zblee
Sep 19, 2015 06:33 PM
