TOWING & OFFROAD PERFORMANCE Towing |Suspension | Wheels | Tires | Drivetrain |where the pavement ends.
How much do larger tires realistically affect performance
Old Oct 27, 2009 | 12:31 PM
RandomHero's Avatar
Originally Posted by DozerDan
Dodge 'em what is your drop? Could do it like tylers. His looks pretty badass. Cut a coil off the front springs and put hangers in the back
I'm basically running a 4/8. My leaf springs are sagging pretty bad so it sits pretty damn low. I may just install the helper bags and run a **** load of psi in them, but I was trying to avoid that. Unfortunately, I heard what I expected to hear. I was thinking maybe a 33" tire wouldn't be too bad, but I guess even that is a big jump.
Old Oct 27, 2009 | 12:43 PM
Phantom's Avatar
11 Second Club
i'm runnin 265/75/17 on my truck right now on some stock caddy wheels. 32.67" i didn't notice any power loss goin from 295/40/20 i do have 4.56 gears though
Old Oct 27, 2009 | 12:45 PM
AJII's Avatar
Wny not just put is at something like a 5 inch drop in the rear, and whatever makes the front level? Will still definately look lowered and not ride like ***.
Old Oct 27, 2009 | 12:47 PM
RandomHero's Avatar
The problem is, how do you recommend I do that(not being sarcastic). That sounds perfect to me, but I've heard lift shackles have problems, and I don't want to run drop leaf springs. I've though about pulling the overload and running the helper bags. That may be the thing to do.
Old Oct 27, 2009 | 12:50 PM
AJII's Avatar
I ran lift shackles for about 2 years and never had any problems at all. What have you heard?
That was probably my favorite setup. It never bottomed out with the notch, and was high enough that I didn't scrape on everything.
Old Oct 27, 2009 | 01:16 PM
cttandy's Avatar
Can't give you any numbers, but you can tell a big difference. I went form just under a 31 to just over a 35, pretty drastic. The biggest difference I notice is to slowing down, the awesome brakes I had before, feels like any normal car now.
The transmission shifts better with the bigger tires, no more gear hunt at all. But hook a trailer behind the truck, and you can tell a huge difference in pulling power.
Old Oct 28, 2009 | 01:37 PM
RandomHero's Avatar
I've heard that they can bind up on the shackle hangers(the rear leaf spring hangers). What kind did you run? The belltechs only drop the truck about a 1/2" so I may try those. They look like they're of a better quality than the DJMs too. I keep telling myself I'll never buy a DJM product again hopefully I'll take my own advice.
Old Oct 28, 2009 | 01:40 PM
AJII's Avatar
Mine we're actually DJM. Never had a problem.
When I ran drop shackles, the rear spring hanger had to be pulled out just a tad bit for it to fit in. And when I put in the lift shackle I never pushed it back, so maybe that's why mine didn't ever bind?
Old Nov 2, 2009 | 03:01 PM
beastmode's Avatar
Import Moderator
Forget track times Mark, just do the 7" procomp
I ordered mine last week for my ext cab 2wd, can't wait to get this thing off the ground, it is going up from a 2/4. Ill be running a TR224, SST3200, LTs and most likely some 4.56s and that will be plenty enough performance for me.
Haven't decided on tire/wheel yet but it doesn't matter because I too broke to afford them
I feel you on babying the truck man... I am tired of pot holes and not being able to go through a little mud... more than anything though I hate having to jack my truck up just to change the oil or work on it
Old Nov 2, 2009 | 03:14 PM
Well I can certainly tell a difference in performance on my truck. Granted its basically stock but with a taller gear and bigger tires should even everything out.
