TOWING & OFFROAD PERFORMANCE Towing |Suspension | Wheels | Tires | Drivetrain |where the pavement ends.
Help, Rear suspension on Tahoe sagging.
Old Jul 25, 2005 | 03:33 PM
Default Help, Rear suspension on Tahoe sagging.
I don't know much about suspensions and towing. I was wondering what you 4 x 4 guys recommend I do about trying to raise the rear of my Tahoe to match up with the font? It sags about 1 to 2 inches without any weight. I plan of pulling a trailer soon and need to beef up the suspension somehow.
Let me know what my options are. I would like to at least have it level when I'm not towing or hauling additional weight.
Thanks!
Old Jul 25, 2005 | 08:54 PM
z7199's Avatar
Try putting in Beefier springs. I am not really sure the Tahoe setup but you may be able to put suburban springs in there or better yet 2500 suburban springs in there?
Old Jul 25, 2005 | 10:20 PM
v10sport's Avatar
Put in an Add a Leaf. You will lift the rear 2.5" to 3"
Old Aug 7, 2005 | 08:56 PM
TURBHOE's Avatar
i think it is a coil spring back there isn't it. might try a spring spacer. or take out the springs and put bags in instead then you could even level it off while towing.
Old Aug 8, 2005 | 07:14 PM
facn8me's Avatar
Air bags or new springs. I recomend both. The springs to get back to factory ride height and bags to help contol the weight and sway of the trailer.
Old Aug 11, 2005 | 11:13 PM
bud8fan's Avatar
which air bags do you guys recomend....
Old Aug 13, 2005 | 05:16 PM
facn8me's Avatar
I've delt with the firestone's the couple of times I've installed them but most systems are basically the same. I looked at stylinconcepts and they offer a couple of different systems for the tahoes.
Old Aug 14, 2005 | 10:05 PM
Just get the fat women outta the back
Old Aug 18, 2005 | 07:47 PM
GKR's Avatar
GKR
If its NBS with coilsprings, the airbags work well. I ran them on my lifted 02 for a few years. The factory springs are a really light rate. They also rely on the shocks to carry some of the weight. I needed longer shocks so went with 12" 5100 which only worsened the spring situation. I was running an RCD lift witch uses spacers for rear lift and after adding my rear bumper/tire carrier/winch set up and spare parts, I was running the bags maxed and still sagging. I also pull a 4800 lbs camp trailer with it. I ended up going with Superlift replacement springs which are a heavier coil. I still run a 1" spacer to level it out. No airbags long enough for my new setup.
If your stock height or lifted with spacer and keep weight resonable, the airbags should work perfect. I went with Firestone but they are all pretty good.
Old Aug 21, 2005 | 06:31 PM
Snacktime's Avatar
Made in South Korea
My grandfather has air ride kit in the back of his suburban. Fully aired it raised the rear 3 inchs unloaded.
SLOPONY
20
Oct 18, 2016 06:05 AM
Corvette454l88
Sep 1, 2016 01:24 AM
chopperloco
Jul 10, 2016 10:45 PM
DarkhorSe_SS
Aug 20, 2015 08:58 AM
brandon6.0
Aug 7, 2015 11:22 PM
