TOWING & OFFROAD PERFORMANCE Towing |Suspension | Wheels | Tires | Drivetrain |where the pavement ends.
GMT900 Yukon axle swap questions
Old May 24, 2021 | 08:39 PM
kendogg's Avatar
Default GMT900 Yukon axle swap questions
Hey everybody. I've searched and found some info, but having a hard time parsing thru trying to figure out whats real and whats BS. Have an '07 Yukon 1500, 2wd. Looking to swap the rear to a 14 bolt. From what I'm reading, GMT900 Escalades and some other SUV's (maybe even Avelanches?) MIGHT have a compatible rear? Ideally, I'm looking for something thats almost a bolt in. I don't mind if I need to get the driveshaft shortened, but I don't want to have to customize the axle if I don't have to. And would prefer to keep my brakes as well to keep correct btake bias. Can anybody help point me towards correct compatibility info please? Thanks!
Old May 24, 2021 | 09:23 PM
arthursc2's Avatar
07+ 6.2 SUV rear end with the same gear ratio and party
car-part.com
Old May 25, 2021 | 09:44 AM
kendogg's Avatar
And my brakes will bolt to that axle without issues? What about parking brake cables?
Old May 25, 2021 | 09:55 AM
arthursc2's Avatar
should be fine, its the same generation truck. Same chassis and suspension and transmission (in the case of 6.2 or 09+ 5.3)
Old May 25, 2021 | 04:23 PM
kendogg's Avatar
Well, this ones been swapped to a built 4l80 (after a couple exploded 4l60's). Hopefully we won't need to shorten the expensive driveshaft lol. Thanks!
Old May 26, 2021 | 11:43 AM
dantheman1540's Avatar
SHouldn't need a drive shaft just a conversion U joint which will probably fail since they are hollow. If your truck currently has a 10bolt rear axle you may need to take the brake baking plate off the old axle and put it on the new axle or else the rotor won't fit over it. AT least that's what I had to do but I also had a 2004 truck and you have a 2007 so you might be good to go.
Old May 26, 2021 | 02:49 PM
kendogg's Avatar
Thanks for the tip! I'll definitely make sure that gets checked before it goes together!
Old May 26, 2021 | 03:11 PM
If you do have to switch them its kinda a PITA because you have to pull the Clips and axle shafts of both axles. It's not rocket science but it can be annoying.
Old May 26, 2021 | 05:39 PM
kendogg's Avatar
Well, I'm getting a used axle, so it's gonna come apart and get a good inspection anyways before it goes in. Might do new axle seals and/or bearings while there. I'm a big believer in a\ pound of prevention etc.
jsanford
Aug 14, 2020 02:30 PM
malibudave
Oct 30, 2018 01:41 PM
jmchillninptown
Feb 19, 2009 09:10 AM
Lord Aries
Nov 4, 2007 01:08 PM
