TOWING & OFFROAD PERFORMANCE Towing |Suspension | Wheels | Tires | Drivetrain |where the pavement ends.
engine getting hot when towing.
Old 02-11-2018, 08:43 PM
ls6musclehead's Avatar
In for what OP does to fix this. How does your truck do power wise pulling that size trailer?
Old 02-12-2018, 01:03 PM
SuburbanStevie's Avatar
Default Check distributor shaft bearings
I had similar problem for several years. Everyone suggesting I do things to cooling system and catalytic converter. Dumped a lot of money chasing the problem. As last ditch effort took truck to a private mechanic who quickly found the the distributor shaft bearings were shot (bronze journal bearings). He replaced and I've never had a problem since. Apparently the timing was firing randomly +/-10°.
Old 02-12-2018, 04:06 PM
SuburbanStevie, it is a 6.0l lq4 LS engine. It has coil near plug ignition. Crankshaft position sensor and camshaft position sensor and uses an ecm to determine ignition timing. No distributor.
Old 02-12-2018, 07:02 PM
gonzo 6.2's Avatar
The other day I bought a 04 Avalanche ,seller said it needed head gaskets or an engine as per his mechanic.I seen a full clean coolant bottle and clean oil and it ran great,bought it drove home 25miles was running 260*.Came home put a new OE temp $12 thermostat in it and its perfect,old one was stuck.
