Can these tires fit under my 05 chevy?
Originally Posted by inmywhitez
nice truck mabutler! how much does a body lift installed cost? well, i guess i would have to get new wheels. spacers wouldn't be safe would they?
Most people think spacers are bad and there are some very good reasons for it because half of them are crap and could kill you. However, with quality parts I have known a few people to run them and like them a lot. Here is a good place to get them if that is what you want to do.
http://www.wheeladapter.com/
Originally Posted by mabutler
You won't be able to run 305/55R20's without a body lift.
They might make a 315 which would be wider or you could use spacers.
Inmywhitez, I think you could probably run them, you just need to do a bit of trimming on your inner fenders and crank your torsion bars if they're not already.... any pictures of your setup? Also, if you want your tires to stick out, you'll need a wider wheel. Your wheels probably have 6" of backspacing or so
i don't have any current pics, but i will try to get some. i do have ford keys and have them cranked a little. my front sits a inch higher than the rear. i just dont want too much rubbage even if i cut the plastics. thanks for yalls help.
You can't run a 305/55 on your truck the way it is now unless you don't mind your trimming to include sheet metal.
If you are wanting to go with a taller tire, then you will need another form of lift.
If you just want wider, then look into new wheels or spacers.
00Silverado, what is your setup and what is a "tad"?
They're 305/50s, but I'm positive I could fit them 55s if I wanted to. Being that I just bought the tires I won't be switching them out for awhile I hope.
This guy on another board runs a 305/55 on 20x8 Centerlines with 5" bs. He has GK torsion bars and Ford Keys.
