TOWING & OFFROAD PERFORMANCE Towing |Suspension | Wheels | Tires | Drivetrain |where the pavement ends.
auto 4x4 vs 4x4 hi
Old Dec 7, 2006 | 04:21 PM
hourang's Avatar
Default auto 4x4 vs 4x4 hi
Anyone know the difference between auto 4x4 and 4x4 hi? like how does it work? same gearing? mph limits? turning radius? etc.
Old Dec 7, 2006 | 04:28 PM
thunder550's Avatar
High on diesel fumes
4hi locks your front hubs all the time - auto only locks them when slip is detected. Auto 4x4 is safe to drive on pavement AFAIK, 4hi is not. Same gearing.
Old Dec 8, 2006 | 01:31 AM
Bo185's Avatar
Aren't the hubs locked all the time on the IFS trucks? The autotrac engages and disengages the front diff. when rear wheel slip is detected. And Four HI/LOW locks it in.
Old Dec 8, 2006 | 03:48 AM
dewmanshu's Avatar
Moderately Differentiated
correct. I broke my lock back when I had my 5.3/radix combo. I had it auto on a rainy day and nailed it. All it is a plunger that pushes an axel spline coupling over the left side of the diff. Don't know the technical terms, but a pretty simple operation.
Old Dec 8, 2006 | 08:25 AM
hourang's Avatar
so is it bad to use autotrac then? i like to use it in the rain for launching.
Old Dec 8, 2006 | 08:28 AM
thunder550's Avatar
Don't use it for launching - just choose 4 hi. It takes a certain amount of slip before it engages - you don't want any slip.
Old Dec 8, 2006 | 04:13 PM
LOGICUSER04's Avatar
Does Launching In 4 Hi Hurt Anything.
Old Dec 8, 2006 | 04:16 PM
kbracing96's Avatar
No, I do it all the time at the track and some times on the street
Old Dec 9, 2006 | 12:34 PM
spitfire2332's Avatar
these threads pop up every now and then. Some one will always argue launching in auto 4 is fine.
If you're questioning launching in 4wd, you obviously dont want what... slip. And like thunder550 said, when you launch in auto 4 it has to slip before 4x4 engages.
Old Dec 10, 2006 | 08:55 PM
hourang's Avatar
well what i do want is the ability to drive around in the rain/snow without worry about traction or driving on dry spots, and without worrying about breaking anything. if the only downfall of using autotrac is slippage, it sure as hell beats one wheel peel im not looking to race here, my transmission cant handle that right now anyway, just dont want to drive like a grandma at a stop light.
