TOWING & OFFROAD PERFORMANCE Towing |Suspension | Wheels | Tires | Drivetrain |where the pavement ends.
4wd conversion
Old Jan 24, 2011 | 09:39 PM
adf5565's Avatar
Registered User
Default 4wd conversion
I am interested in converting my 2wd 2000 1500 silverado to 4wd. I was planning on buying a salvaged truck and swapping the stock suspension and steering parts from that along with the 4wd auto transmission and the transfer case that has manual actuation into my truck. However I was wondering if there were any sensors/electrical connections on the 4wd transmission that would be different from the 2wd version.
I know it probably would be easier to just buy a 4wd truck but mine is in good shape and I could get a decent salvaged truck with all the parts I need for alot less.
Old Jan 24, 2011 | 10:04 PM
andrew383's Avatar
traveling mod
The only thing i can think of since yours is a manual case is the sensor that tells the front diff to lock in but that should be on the shifter assembly..
Im also not sure how the hole in the floor is going to work out either..I havent been around to many floor shift silvys..
Old Jan 24, 2011 | 10:32 PM
pkozera's Avatar
I swaped a manual case into my 99 silvy. Auto trac sucks.
Old Jan 24, 2011 | 10:46 PM
viciousknid's Avatar
Where's the Beef?
I thought the frames were different between 2wd 4wd trucks these days?
Old Jan 27, 2011 | 10:52 AM
Summitwhite06's Avatar
I'm pretty sure they're the same except for a few mounts which can be added.
OP: if you're going to go through all the trouble of converting your truck to 4wd I would just go ahead and do an SAS instead of completely replacing the IFS and adding torsion bars and whatnot. In the long run it's going to be about the same amount of work
Old Jan 28, 2011 | 08:11 AM
1bad2k's Avatar
Its actually where the cubby hole/traction control button is to the left of the cluster, so that shouldnt be an issue to pick one up.
As far as the frames, they are different. They (4x4's) have the torsion bar front suspension without coils.
How hard it would be with a good welder and some skills to change that..... I dont know
Old Jan 28, 2011 | 01:35 PM
ig109's Avatar
Frames are completely different from 2wd to 4wd until you get up into the NNBS trucks..
This swap will not work unless you change frames
Pimpinpete
43
Dec 22, 2017 08:13 AM
Silver8ado
Sep 30, 2015 11:42 AM
Blklgt
Sep 28, 2015 03:21 PM
sTNT971
Sep 26, 2015 04:22 PM
spooneralmighty
Sep 11, 2015 02:28 PM
