TOWING & OFFROAD PERFORMANCE Towing |Suspension | Wheels | Tires | Drivetrain |where the pavement ends.
14 bolt vs built 10 bolt rear end
Old 01-07-2017, 08:03 PM
nathanstowing's Avatar
Default 14 bolt vs built 10 bolt rear end
as the title says guys..my 10 bolt is going out (bad bearing) and thinking about rebuilding it with better gears and stuff or just finding a low millage 14 bolt from a ss or vortex max truck, i have a 03 rcsb z71 and also thinking of doing the awd swap in the future so what do you guys recommend so it could flow all together and be fast out the hole??
Old 01-07-2017, 08:58 PM
91LT16SpeedFormula's Avatar
Most guys will prob say the 14 bolt is junk bc of the gov-lock carrier. The 10 bolt has more options as far as upgradeable parts also
Old 01-08-2017, 12:23 AM
LPCWS6's Avatar
From my experience of breaking $hit I have promised myself to never attempt to build another 10 bolt or 4l60 for matter. IMO a waste of money.
Old 01-08-2017, 09:04 AM
11 Second Club
MrHorsepowerLSx's Avatar
The money/time that you will spend on/finding the 14b AXN axle, you could bullet proof your 10 bolt. IMO. Also think of the rear in your truck as the GN rear that many racers look for to swap their "lesser" rears out for. The rears in our trucks are really not that bad, and plenty of members are pushing big power through them
Old 01-08-2017, 12:05 PM
thanks guys I'm aiming more for a 14 bolt since i rather just do it right the first time and also upgrade to disk brakes..
Old 01-08-2017, 12:47 PM
1994Vmax's Avatar
Depends..... I didn't want some gov lock junk in my 14 bolt either so I just redid my K5's 10 bolt. Regardless I was buying gears, bearings and a carrier..... so why bother buy the entire axle over and above that. Not to mention zero fab work in my case and no 8 lug to 6 lug etc.... I doubt I will ever break my trucks 10 bolt as it's not hardcore anything and has a little over 500 hp LS3 in front of it. Sometimes simple works too.
Old 01-08-2017, 02:23 PM
i get what your saying it is a headache doing the swap but will a built 10 bolt hold a lot of power?im aiming for 650-700 hp now but i would like around 1k hp in the future and don't want to be rebuilding my 10 bolt and keep waisting money on it..
Old 01-08-2017, 02:27 PM
i get you would a built 14 bolt be better then a built 10 bolt or is just heavier and bigger??im aiming for a lot of hp and looking to get it right the first time..
Old 01-08-2017, 02:50 PM
3wide's Avatar
If you are shooting for between 700-1K than just spend the money correctly on a well built 9" rear. There are way more choices for the 9" than for the 10/14-bolt combined. The 9 can be built lighter and stronger than 10-bolt.
Old 01-08-2017, 03:16 PM
thanks for the advice where can i find one and what gears do you recommend to go with it, I've been looking at moser rear ends but there kinda pricey but worth it probably
