14 bolt SF
#31
Cool thread. I've got a 99 NBS ECSB. I bought a 9.5" 2KXX axle and regeared it from 3.42 to 4.10. This thread is motivating me to try to swap it. I hope I can do it with a bit of cutting and welding.
My truck did get swapped to a 4L80e, but I don't remember what the yoke that I used. It came from Denny's driveshaft. The driveshaft itself was not shortened, as the center bearing carrier crossmember has slots that allow the adjustment.
#32
strutaeng (09-19-2022)
#33
I believe when I measured the WMS it was like 1/2 or 1" wider compared to the WMS of the GMT 800. I actually compared it a 14 bolt 10.5" disc that came from a gmt800 2500HD I had laying around. I assumed it's the same as the 10 bolt?
I have the 12 bolt in my garage, but haven't put back the axles. I have the 16" factory rims on my truck and I confirmed they won't clear on the 12 bolt, so I'll need something larger.
Harrycackalingus (09-20-2022)
#34
Yes. 12 bolt cover. I think they are calling it the "12 bolt?" Obviously, not the same 12 bolt from the 70s. It seems to be like the AXN, but I don't know enough about any of them honestly.
strutaeng (09-24-2022)
#36
I tried using the silverado 2500 backing plate, because I dont have any rear wheel speed sensors on this truck. The silverado backing plates don't have that provision. I could have carved out the center. figured it was easier to just block off the abs sensor hole instead.
Hummer h2 backing plate on h2 anchor.
Silverado 2500 backing plate wont fit the h2 anchor. The center bore is too small.
#37
First impressions of the work.... Brake pedal travel sucks. I hope Hydroboost helps. The only solution i know. I swapped in the bigger 1.25" master and its not enough. I think thats the biggest master that is vacum boosted and bolts in? The gearing change is awesome!! Truck came alive. 3.73s and 35s suck!!! Also need a longer passenger side e brake cable.
I changed compression valving and went to a heavier spring in the front. The truck ran out of travel early before.
So need some tweaks before dialed.
strutaeng (10-09-2022)
726.0chevelle
07-09-2012 07:41 AM
