-   TOWING & OFFROAD PERFORMANCE (https://www.performancetrucks.net/forums/towing-offroad-performance-168/)
-   -   14 bolt SF (https://www.performancetrucks.net/forums/towing-offroad-performance-168/14-bolt-sf-559804/)
Harrycackalingus Sep 2, 2022 11:50 AM
Making some progress. I think it has a decent width. Of course I wouldn't mind it wider. But still looks pretty good. The bedsides are pulled almost 2" per side. Front fenders are 2" flare also. So it doesn't look as wide as it is. Still have to set pinion angle and tack everything up.https://cimg6.ibsrv.net/gimg/www.per...637b9d357d.jpg
https://cimg0.ibsrv.net/gimg/www.per...a06465c171.jpg
https://cimg3.ibsrv.net/gimg/www.per...83b1bc252a.jpg
https://cimg4.ibsrv.net/gimg/www.per...ccaf6836e6.jpg
https://cimg3.ibsrv.net/gimg/www.per...a415907433.jpg
Harrycackalingus Sep 9, 2022 10:19 PM
Was looking over the driveshaft. My truck came factory with 1350 U joints. Took dimensions to verify. They always looked like they would fit the yoke of the 14 bolt. Im not very familiar with different U joint sizes. Can't spot them visually. Also I've seen threads on cutting of 5/8" of driveshaft length doing a 14 bolt swap. My truck needs way more then that. Don't have any final measurements but, it's more then .750".
1FastBrick Sep 9, 2022 11:25 PM
The factory 2 Piece drive shaft is 5/8 of an inch shorter than its 10bolt counter part. On a single shaft application you need to remove more.
On a regular cab truck I played with it was like 7/8 that it had to be shortened.
It's always best to measure. Who's to say the guy cutting the tubes didn't cut a hair longer or shorter from 1 day to the next. Or that one didn't shrink more than another based on how it was prepped and welded.
Harrycackalingus Sep 10, 2022 03:44 AM
Good point. This forum is awesome. lots of good info! I will update with how much I had to cut off.
dantheman1540 Sep 10, 2022 06:40 AM
Also if you want to be extra beefy you can buy a 1410 yoke for the pinion.
Harrycackalingus Sep 10, 2022 04:31 PM
https://cimg7.ibsrv.net/gimg/www.per...00a1a0170c.jpg
Harrycackalingus Sep 10, 2022 04:33 PM
Do 4l80e trans use 1410s?
Harrycackalingus Sep 17, 2022 08:58 PM
https://cimg2.ibsrv.net/gimg/www.per...065d672ef1.jpg
https://cimg3.ibsrv.net/gimg/www.per...bc878473ae.jpg
https://cimg4.ibsrv.net/gimg/www.per...2483bb6d94.jpg
had to pull the coils for a rebuild. Some glamor shots.
Bgbldodge Sep 17, 2022 09:39 PM
That’s badass. Love it.
dantheman1540 Sep 18, 2022 12:06 PM
Not sure, I’ve never had an 80E.
front travel looks great!
