TOWING & OFFROAD PERFORMANCE Towing |Suspension | Wheels | Tires | Drivetrain |where the pavement ends.
02 2wd leveling kit
Old Sep 11, 2007 | 05:38 PM
RandomHero's Avatar
Originally Posted by 53bowtie
i know that way would be cheapest but i would like the least rough ride possible with a lift....
here is what i want: the truck to look more beefy with out compromising 1)ride quality much and 2)my wallet.......if i could do that i would be one happy guy
best bet is to do something like this: http://cgi.ebay.com/ebaymotors/CHEVY...spagenameZWDVW
You won't need new shocks in the front and you can probably find some shocks off a stock z71 for cheap. That would look almost like my old setup on my truck:
That setup cost me:
Fabtech 3" spindles-$275
2" Coil Spacers(sat about 1" though)-$40
305/70/16 tires-$100
pro comp 16x8-$300
Shocks-$12.50 each
Everything I bought I got used in great condition. Basically I had that lift/rims/tires for <$800
Old Sep 11, 2007 | 09:58 PM
53bowtie's Avatar
That setup cost me:
pro comp 16x8-$300
Shocks-$12.50 each
thanks man, that is exactly what i am lookin for!! would i need the coil spacers if i got 4" spindles?
and that kit comes with blocks and longer u bolts to all i would need would be shocks.....
it is in my price range for sure and if that is what that maroon truck has that is the hieght i want mine at so this looks like what i will do....
Old Sep 11, 2007 | 10:01 PM
53bowtie's Avatar
and what is the overall diameter of those tires you ran? thanks.
Old Sep 11, 2007 | 11:41 PM
RandomHero's Avatar
They tires were 305/70/16. Something like a 11.5" tire.
Yea if you got the 4" spindles it would look almost identical to mine. I ran a 4" block though and it sat completely level(which seems weird to me). If I were you I'd run a 2" block.
Just know that I had to trim quite a bit to clear those. I think I would have had WAAY fewer problems if I ran 285/75/16's instead.
Old Sep 12, 2007 | 05:52 AM
beastmode's Avatar
Import Moderator
damn mark you musta done ALOT of trimming im just shocked that it fit those tires.
was that the actual kit you used on the ebay link? for the rear you said you used 4" blocks instead of the factory 4wd blocks? it appears that you are sitting level, thats def weird
Old Sep 12, 2007 | 10:39 AM
Tootall's Avatar
are you doing this for looks, or are you going to baja it ?
Old Sep 12, 2007 | 01:23 PM
RandomHero's Avatar
No I didn't use that ebay kit. I was merely suggesting it. My kit was listed below the picture and was a 3" spindle 2" coil spacer. I bought the block separate with ubolts for $20 shipped. The front really only sat about 4.5" though.
In response to this:
Every kit under $2500 is pointless to turn it into a prerunner. You need a longtravel setup with coil overs or at least the longtravel cst lift and to run those you need glassed fenders.
Old Sep 12, 2007 | 05:56 PM
53bowtie's Avatar
def. not baja by any means.....just want the truck to look more beefy thats all.....
Old Sep 13, 2007 | 08:58 AM
Tootall's Avatar
ahh then just get the spindles. They go on pretty easy, and the front will still ride as if it's stock. Everything goes back in their stock positions.
silverstreak07
Jun 28, 2016 06:29 PM
nickpc82
Nov 2, 2015 02:49 PM
Verz
Aug 21, 2015 06:40 PM
khoult
Jul 15, 2015 03:54 PM
