TOOLS & FABRICATION Hand | Power | Hydraulic | Pneumatic | Welding
Homemade Dyno
Old 01-12-2015, 12:26 PM
marketmerlin's Avatar
Default Homemade Dyno
How does a dyno work exactly? I know it loads the tires in an attempt to simulate a real life pull, but does the breaking effect of the dyno need to be constant or does it need to be greater as the RPMS climb
Old 01-12-2015, 12:50 PM
What I was pondering is if you could use magnets and aluminum as a brake/resistance for a dyno. Seems like a dyno would be cheap that way. Just get a truck rear end with aluminum wheels and weld the spider gears and mount some industrial magnets close to them and would have the same effect. Are there any dyno's set up like that?
Old 01-12-2015, 01:11 PM
oakley6575's Avatar
Read up on how eddy brakes work.
Old 01-12-2015, 01:22 PM
Aww what's the fun in that lol I drive a truck for a living and don't have time to do a whole lot of heavy reading
Old 01-12-2015, 01:26 PM
dirt track racer 81's Avatar
So how you going to read any hp or tq numbers?
Old 01-12-2015, 03:34 PM
They actually have kits from what i was reading the other day with program, some little computer box and sensors for about $1000. I'm not about to build one. Just curious how it was all set up and if any of them used the eddy brake effects.
Old 01-12-2015, 05:58 PM
charcoal03silvy's Avatar
There are plans and such out there on how to build them.. The problem will be the software to control it and and gather/interpret data.
Old 01-12-2015, 06:25 PM
Resident Retard
BlackGMC's Avatar
Please video the first vehicle. Also update your will prior to starting.
Old 01-12-2015, 06:54 PM
DTec Dynertia- DIY Inertia & Brake Dyno (Dynamometer) System
Old 01-12-2015, 06:57 PM
Annnnnd tadaaaaaa How to build your own dyno for just $2,000
Quick Reply: Homemade Dyno
