TOOLS & FABRICATION Hand | Power | Hydraulic | Pneumatic | Welding
2 piece driveshaft crossmember
Old Oct 28, 2015 | 06:40 PM
ronnie lueck's Avatar
Registered User
Default 2 piece driveshaft crossmember
I have a 2006 gmc crew cab on a 4/7 drop and am wanting to put a 2 piece drive shaft under it. where can I get a cross member for the carrier bearing?
Old Jan 26, 2016 | 06:59 AM
iamkeniff's Avatar
Custom make one or you can have a welding shop make you one
Old Jan 26, 2017 | 10:26 AM
digitalfiend's Avatar
Hi there. I've got a 2004 Chevy Tahoe that has a single-piece driveshaft so it's a very similar drivetrain setup as your ride. I'm curious why you would want to do this. Is there some performance advantage or another reason? I'm not being a smartass, I just want to understand if there's a benefit over a one-piece driveshaft.
Old Jan 26, 2017 | 10:57 AM
thewrx's Avatar
so you can keep pinion angle in check, when your slammed or bagged.
pewter00
Nov 21, 2015 02:12 PM
adrian9173
Nov 14, 2015 09:32 PM
07NbsGMCVORTECMAXJC
Nov 3, 2015 02:09 AM
zblee
Oct 28, 2015 12:05 PM
