tonight is the night....
#23
#24
here is the 13.0 run@103 where i flashed it at idle
http://www.youtube.com/watch?v=1nXA4...layer_embedded
and one where i actually stalled it up.....
3.2 60'
http://www.youtube.com/watch?v=5yGOT...layer_embedded
#25
im not going back til i make few changes... i dont think ive ever been that depressed leaving the track.... i feel like i need to be on some anti-depressants lol. i will go back when i KNOW i am in the 12's. i will bring the et streets back to you when we do the 02pcm swap... sound good? oh and BTW, thanks a lot for that trans cooler!
I think there is more going on than just the 60' here. i gained a little less than 2mph from my previous best. i figured i would be trapping over 100mph
3.92 with a 28" tire so if the 3400 stall doesnt help much ill make my truck just a track truck and throw 4.56 with the 3400, cause this one guy gained 3 mph in a reg cab with a 3400 from going from a 3.92 gear to a 4.56
#26
17,16,15,14,13,12,11 Drvr
good to see ya there jeremy, sorry you didn't run the times you wanted, have charlie look at the tune again and then try and see if it will break stall to atleast 2k, but I would believe 3200 is good for the 224, hell I was running a 2800 with the 226 cam.
#28
charlie has an 02 pcm headed my way..... still fighting with some idle issues in gear.... maybe the pcm was reading some false knock and pulling 15 degrees of timing
wishful thinking
#29
i was the same way lastnight...i feel you pain i should been in the 12.7 range but first time running it i felt the lost of low end compared to the old cam
#30
