Texas We've Seceded from the Union
Rookie mistakes...4.8 torn down to bare block
Old May 19, 2016 | 11:01 AM
BLWNLT1_T/A's Avatar
Default Rookie mistakes...4.8 torn down to bare block
Long story short. Tore apart a 4.8 going to get new cam bearings, main bearing, honed and re-ringed. Where I believe I messed up is I didn't label the rod caps nor did I put them back on the same rods I took them off of. Any way to identify them or am I screwed?
Old May 19, 2016 | 11:21 AM
madmann26's Avatar
Outside of stamping/marking them, I don't think so. You'll need the mains lined honed and the rods/caps machined so they all match.
Old May 19, 2016 | 12:32 PM
Wolftrk99's Avatar
Theyre broken rods so they need to go back with their mate...... Close enough wont cut it on those.... You could actually take the cap and match it to the rod by putting them together and of the line between them all but disappers you should be good.... Lessons learned!!! Weve all been there!!!
Old May 20, 2016 | 01:20 PM
Thanks for the help guys... Took it all to the machine shop this morning Block vat, new cam bearings, main bearings, rod bearing, turn the crank, and resurface the heads... 700.00 bucks
Old May 20, 2016 | 02:34 PM
Wolftrk99's Avatar
They going to match your rods and caps up for you??
YAMAHAGUY
May 22, 2016 01:19 PM
tim wellington
May 9, 2016 09:01 AM
chevyfan454
16
May 6, 2016 11:36 AM
nova421
Apr 22, 2016 10:35 AM
