need a thread chaser for heads
im wondering if anyone near me has a thread chaser that i can borrow or rent so i can install my head studs.. located south of ft worth.
needing m8-1.25 and m11-2.00
if so please pm me
thanks ray
if so please pm me
thanks ray
Just grind down the old head bolts so there is a flat surface. Alterative is to buy the ARP chasers.
I just installed heads and got fed up with the tap and paper towel deal, so I came up with a solution: take a $20 walmart "mini" wetvac, duct tape a straw to the end of it. Spray the bolt holes with brake cleaner and then suck it out with the wet vac. Repeat x 1 and my bolt holes were pristine. And I could do each bank in 15 minutes.
I did exactly what GMC said, took a stock head bold, ground 2 sides flat, cleaned it up nice and went to town, that was about 8 years ago and that old bird is still running strong.
when I started the process I took an air nozzle and blew the bolt hole out good, I did them one at a time, blow it out, stuff a kleenez in it, do the next one, same step for all of them. once they were all clean, I went back and pulled the kleenex and used the chaser, again, one at a time to ensure that each was clean. I didn't have any issues. Some of the studs need a little extra nuttup to get it down in it's spot, but not to much.
zblee
63
Jun 10, 2023 01:25 PM
superchomper2003
Aug 26, 2015 09:39 AM
TX Tahoe Z71
Aug 7, 2015 03:58 AM
sauldgold
Jul 23, 2015 02:15 PM
