Texas We've Seceded from the Union
Delphi 42# injectors (01D030B)
Old Feb 21, 2010 | 12:36 PM
Noah Burns's Avatar
Default Delphi 42# injectors (01D030B)
These are slightly used and ready to go, they were cleaned by Brucato (boat guys but they clean and flow injectors)
Asking $250 for them obo or might trade possibly for the right parts but prefer to sell... motivated to sell so make a reasonable offer...
here is the information on the injectors...
Delphi / Lucas
42 lb / hr. '009' Disc Injectors
Part Number Delphi 01D030B (Lucas old 5208009, Lucas New 621031)
Static Flow Rate: 42.29 lb/hr @ 43.5PSI (300kPa) or 320gm/min
Dynamic Flow Rate: 9.96 gm/pulse - 2.5ms pulse width and 10ms repetition rate
Coil Resistance: 15.9 Ohms / High Impedance / High-Z (No ECM driver modifications required)
Additional Information:
Top feed disc injectors use a small disc with six holes around its circumference. The disc rests on a short chimney that surrounds a metering hole. As the disc is raised off the chimney by magnetic force, fuel flows through the holes in the disc, over the walls of the chimney, and out the metering hole to form a full, finely atomized cone.
Performance advantages over pintle injectors (i.e. Ford / Bosch & Accel types) as listed by Delphi:
• The flat mating surface ensures that no excess fuel is present to evaporate and therefore, no deposits or clogging can occur.
• Compatible with alternative fuels (i.e. Methanol)
• Longer service life
• High-speed disc action allows wider dynamic flow range for improved idling
• Quieter operation
• Revolutionary disc design resists build up deposits which can affect fuel flow.
• No Fuel leakage for quicker starts
Old Feb 21, 2010 | 06:33 PM
Noah Burns's Avatar
meant to put $200 as the asking price... for some reason it won't let me edit the original post...
Old Feb 22, 2010 | 10:28 AM
banker099's Avatar
do they plug in the factory truck harness?
Old Feb 22, 2010 | 12:40 PM
Noah Burns's Avatar
no idea honestly...
$A_Money$81
Mar 27, 2023 10:25 AM
shootermwc
Oct 8, 2015 01:45 PM
KleanKustoms
Sep 30, 2015 05:07 PM
Wrecker 426
Sep 29, 2015 11:00 PM
sTNT971
Sep 26, 2015 04:22 PM
