TECHNICAL WRITE-UPS A place for great instructional threads by members and moderators.
HOW TO: Replace knock sensors on a GMT800/GEN III V8
Old Dec 7, 2010 | 09:35 PM
DV2000NJ's Avatar
13 Second Truck Club
Nice, sounds like you sent Santa your list already My truck's a tidbit too filthy for pics at the moment, but I haven't put the winter wheels on it yet...so it's not out of the question...maybe some snow shots!
That's what I was thinking, with the truck being black and all.
Old Dec 8, 2010 | 07:57 AM
Tootall's Avatar
you might want to add . . .
To bleed off the fuel pressure, start the truck, remove the fuel pump relay, let the truck idle and die.
Old Dec 9, 2010 | 08:26 PM
AndysC3's Avatar
For the knock sensor sub-harness. Its listed as the knock sensor wire. The part number is 15320925
Old Dec 14, 2010 | 09:56 PM
Low_S-10's Avatar
some of the techs where i work put a bead of rtv in front of the rear knock sensor hole and remove the foam from the rear of the intake to let the water run off the back of the engine better.
here a pic of where they put the bead of rtv
HOW TO: Replace knock sensors on a GMT800/GEN III V8-img_0443.jpg
Old Dec 15, 2010 | 02:46 AM
ByuTrukr's Avatar
formerly ByuTrukFreak
I couldn't figure how to get the connection off the knock sensor, so you might want to add that you have to squeeze the connection with a pair of needle nose pliers in a certain place to remove the plugs without breaking them.
Old Nov 30, 2011 | 12:15 AM
2lugnuts's Avatar
DV2000NJ,
Thanks for the post and all the pictures man just did mine today so the play by play worked. "No engine code", replaced both sensors, harness, gaskets and built my silicone dam.
Old Nov 30, 2011 | 09:17 AM
Slammed96's Avatar
I'll be doing this soon...the code just popped up for me
Old Jan 11, 2012 | 09:51 PM
hsiriyob's Avatar
i was sweating this code until now. great write up!
Old Oct 23, 2013 | 02:57 PM
speedie mc pete's Avatar
Thanks to DV2000NJ for this write up! I know it's more than 2 years old but this is the 1st time I've had to dig into a motor by myself. I know I know most of you guys dig in way deeper than this but for a daily driver for me this is as far as I have gone into a motor.
I've done transmissions, front and rear axles brakes stem to stern on may cars/trucks but when it came to motors I farmed it out.
Thank you again, your pics and step by step helped out tremendously.
OHsixLS3
Dec 27, 2016 09:30 AM
Fast86z
Aug 23, 2015 12:35 AM
Jblake
Aug 17, 2015 12:59 PM
OHsixLS3
Aug 10, 2015 07:19 PM
04450r
Jul 30, 2015 02:04 PM
