XM Radio ID question
Old Nov 16, 2012 | 02:28 PM
GBM822's Avatar
Registered User
Default XM Radio ID question
First off, I've searched here and GMFS. This site usually takes around 5 mins to load each page here at work, so I just got fed up with waiting, and I keep getting connection errors over at gmfs, phone as well.
Simple yes or no answer.
If I have a 2005 Silverado with XM and I take out my radio and replace it with a stock navi unit out of another GM truck (non-lux, I already have all that squared away), will I have to transfer my XM to this radio?
Im assuming that the ID number goes with the truck, not the actual radio. So, I am assuming the answer is NO.
Thanks
Old Nov 16, 2012 | 03:30 PM
TXSZ66AVLANCHE's Avatar
Id goes with the xm module, which is not in the radio.
Old Nov 16, 2012 | 04:18 PM
fastnnuffrt's Avatar
On dodge the id is in the factory radio
Old Nov 17, 2012 | 10:47 PM
GBM822's Avatar
Registered User
Thanks. I figured that it wouldn't be, just needed confirmation from someone who knew.
Old Nov 28, 2012 | 08:16 PM
Chevy_freak's Avatar
Its easy to check and change if need be. I think channel 0 gives you your radio ID. If it does change, call or go to XMs website and simply change the ID.
Id also assume the number is stored in the xm module which is behind the glovebox, but stranger things exist.
Old Nov 28, 2012 | 10:27 PM
jbancs's Avatar
This. Not all vehicles have a separate satellite radio tuner, but GM does, so you're good to go.
Old Feb 13, 2013 | 10:45 PM
partyd's Avatar
Registered User
the XM tuner is behind the glove compartment, right side facing up,
there is a 12 pin plug behind the radio that is the xm connector, just press the band button couple of times until xm1 xm2 shows up and go to channel zero for the radio ID
if your new radio is not recognizing the satellite, go back to the person that program the radio to the vehicle, they need to flash the memory again
andrewlong
Nov 9, 2016 09:38 AM
projectnightcrawler
Sep 30, 2015 10:49 PM
chevstang421
Sep 10, 2015 09:16 AM
carid
Sep 10, 2015 09:07 AM
andrewlong
Sep 8, 2015 10:25 PM
