Wiring!!! Help!
Old Oct 28, 2006 | 12:53 PM
nice_n_lo_silverado's Avatar
Default Wiring!!! Help!
OK so, I have an A'Pexi AVC-R boost controller in my truck that I need to install. It asks for an RPM signal, Throttle signal, and Speed signal. Where can I find these wires? PCM or in the gauge cluster? The instructions ask it to be on the PCM's wiring harness...so thats where I would prefer to wire them. But again, if I can wire it inside the cab and have it run correctly I will do this. You see the instructions ask for a precise voltage and I would like to do that because I don't want to change boost and what not on this controller and have inacurate voltages leading to the demise of my engine. Any help?
Nick
Old Nov 1, 2006 | 11:47 PM
blue 01's Avatar
If you get a Haynes manual for your truck it should have that info in the back section under wiring.
Or might get more help if you post this in the FI section.
Old Nov 1, 2006 | 11:53 PM
OK, done the Fi part. Where can I get a Haynes manual for my truck? I would like to get one but Don't want to spend $100
Old Nov 2, 2006 | 11:06 AM
blue 01's Avatar
Autozone $12.00
Old Nov 2, 2006 | 01:24 PM
Yea. they don't carry them...I've tryed almost everyone in the north-east ohio area! But I did find one online
Old Nov 2, 2006 | 01:34 PM
blue 01's Avatar
I will try to find the wires in my Haynes to night for you.
Old Nov 2, 2006 | 01:35 PM
Thanks!!
Old Nov 2, 2006 | 11:03 PM
blue 01's Avatar
Out of Haynes book
Throttle position sensor =gray #20 5volts
Speed sensor = LT green/black #3 & PPL/white # 4
RPM =white ???
PM me your e-mail if you want a larger pictures
Attached Thumbnails Wiring!!! Help!-2of4a.jpg   Wiring!!! Help!-3of4a.jpg   Wiring!!! Help!-4of4a.jpg
Old Nov 2, 2006 | 11:05 PM
blue 01's Avatar
Better send me your email because I cant see **** on these little pictures.
Old Nov 2, 2006 | 11:18 PM
firemannick1045@yahoo.com
00loudchevy
Dec 3, 2015 05:54 PM
bearden86
26
Nov 15, 2015 03:58 PM
JordanH
Oct 3, 2015 03:59 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
Wrecker 426
Sep 30, 2015 09:39 PM
