Wiring E-Fans to ignition source
Old May 30, 2006 | 10:16 AM
BradS's Avatar
Originally Posted by Nickvrebel
he can install the harness all the way for now except pin 42, use a relay to switch polarity and run that to a hot ignition source to the relay until he gets back, he'll have automatic fans for the a/c, and all the rest of the a/c that would save a good bit of rewiring so it'll be set up to work right when he has them turned on
And there is the other half of the solution
Old May 30, 2006 | 10:37 AM
white1's Avatar
Got parts coming. Fixing to order some more just for yall bothersome biches
Old May 30, 2006 | 11:46 AM
Z284thgen's Avatar
11 Second Club
i dont need fan plugs so dont forget
and i dont think ross needs them as well
Old May 30, 2006 | 11:57 AM
white1's Avatar
I knew you didnt. But I bet both of yall need relays and PCM pins.
Old May 30, 2006 | 12:15 PM
Z284thgen's Avatar
11 Second Club
yeah we do so get to building and less whoring around on this board
Old May 30, 2006 | 01:11 PM
white1's Avatar
I only ***** while Im at work. Cant very well build harnesses right now at work can I? (actually I can, but the weather isnt right, so I might have a problem getting them home. Anyway they take three relays each, and I have 3 harnesses sold already to people that have PAID, so they come first.
Old May 30, 2006 | 05:56 PM
Z284thgen's Avatar
11 Second Club
you havent priced so i havent payed i just ordered and told you to get it built
Old Jun 1, 2006 | 07:56 PM
Ross @ EDO's Avatar
FormerVendor
No need for a harness here, mines on a switch now
Old Jun 7, 2006 | 10:52 PM
Does anyone have a wiring diagram for the e fans. I want them to work with relays and the pcm. I already have the PCM tuned for the fans I jsut dont have the harness. Id like to make my own, or would I be better off buying one from nelson. thanks for the info.
00loudchevy
Dec 3, 2015 05:54 PM
bearden86
26
Nov 15, 2015 03:58 PM
dsbodley
Nov 14, 2015 09:46 PM
JordanH
Oct 3, 2015 03:59 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
