Wiring E-Fans to ignition source
Originally Posted by Nickvrebel
he can install the harness all the way for now except pin 42, use a relay to switch polarity and run that to a hot ignition source to the relay until he gets back, he'll have automatic fans for the a/c, and all the rest of the a/c that would save a good bit of rewiring so it'll be set up to work right when he has them turned on
And there is the other half of the solution
Originally Posted by Z284thgen
i dont need fan plugs so dont forget
and i dont think ross needs them as well
I knew you didnt. But I bet both of yall need relays and PCM pins.
I only ***** while Im at work. Cant very well build harnesses right now at work can I? (actually I can, but the weather isnt right, so I might have a problem getting them home. Anyway they take three relays each, and I have 3 harnesses sold already to people that have PAID, so they come first.
Does anyone have a wiring diagram for the e fans. I want them to work with relays and the pcm. I already have the PCM tuned for the fans I jsut dont have the harness. Id like to make my own, or would I be better off buying one from nelson. thanks for the info.
