what's this amp worth?
#41
apple bottom jeans
I've never heard the Orion's, so I can't help you there.
But you have to decide what you want. SPL, SQ? The SSD's get reasonably loud, and sounds pretty good while doing it. They are like a louder Type X apparently.
If you can fit 12" Orions, you can probably fit 12" Fi's. Same power requirements, just a little bigger mounting depth(and 12") The airspace wouldn't be that much either.
HOw big is the box you have/are going to make/or have made?
I don't know when I can get a fuse, so it could be the middle of next week till it gets running. The box is in and everything though. Ill take pictures in a bit.
#45
i added dayton high output 12's to the list. I think ill remove the HCCA's. If i want good 10's, I'll go for gold with the Fi's. My box has 6.25" mounting depth avail so no Fi 12's. My system isnt going to be THAT great since I'll be keeping the stock bose stuff for a while...maybe i should just save some $$$. Anyone hear the daytons? i wonder how they compare to the orions. I'm wondering if i should go with the extra 400 watts since my amp can provide it.
#46
apple bottom jeans
Dayton from www.partsexpress.com is a very good option as well. Very good subs.
Do you have a router? It wouldn't be all that difficult to route out 3/8's of an inch from the bottom of the box. How much space is between the sub and whatevers in front of it? Could you make a spacer?
#47
they are downfiring underneath the rear bench (ext cab). making a spacer would mean less room for the subs to flex out when they hit so it all depends on how much they need for that. I was considering that option though. I could just buy the MDF speaker ring used for fiberglass boxes and use that as a spacer...but man...those Fi 12's are even more expensive.... i wish money grew on trees
#49
apple bottom jeans
the xmax on the Fi's is 21 mm, P2P. So 10.5 one way, which is about .4 inches. So if you stick 1/2 inch between sub and floor, you should be good to go.
