Want to add factory USB
Old Jun 15, 2013 | 03:08 PM
TIM Z's Avatar
11 sec. Truck Mod
Default Want to add factory USB
To my 09' sierra Denali . Is it as simple as just buying a factory USB harness ?
My truck has factory nav , just wondered if I bought the parts if it would hook up ?
If so anyone know the parts needed ? Reflash of radio needed ?
Thanks!
Old Jun 17, 2013 | 08:41 AM
TIM Z's Avatar
11 sec. Truck Mod
No one ?
I know I can buy an aftermarket adaptor to add a USB , but would like to do it with factory parts if possible.
Old Jun 17, 2013 | 09:47 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Might check on GMFS. Lotta techy ******* over there.
Old Jun 18, 2013 | 08:06 AM
Robert91RS's Avatar
Sorry, just saw your post. First you'll need to find out if your radio has a usb port on the back. My base model radio didnt, so I a swapped it with an LTZ radio and added the cable and receptacle. I had to flash the new radio with my Vin so it knew where it was, but if you have the USB port already that shouldn't be needed.
I used receptacle# 20944422 and cable# 22829189. VIN?
Old Jun 18, 2013 | 08:39 AM
TIM Z's Avatar
11 sec. Truck Mod
yeah I should snoop there , I've never joined due to douchebag attitudes over there , but some good DIY info there .
Thanks man ! I wonder if my VIN will tell if my NAV has a USB port ?
Old Jun 18, 2013 | 01:46 PM
Robert91RS's Avatar
I can check but it may also help ID which cable and receptacle you should use. They have different lengths depending on dash configuration.
Looking back I wish I had just routed the usb cable to the glove box or a dash cubby because I use a usb stick loaded with music and last weekend my 3yr old daughter broke it off the front of the dash getting out. Just food for thought.
Pontiac Derek
Sep 19, 2015 01:49 PM
Pontiac Derek
Sep 18, 2015 09:02 AM
97gmc
22
Sep 8, 2015 10:56 PM
iregret
Sep 7, 2015 01:20 PM
Cakes
Sep 6, 2015 02:57 PM
