Upgrade To a 00 - 02 BCM module
Shouldnt I be able to upgrade my BCM module from my 99 silverado to a 00 - 02 silverado? So i am able to override my headlights at night. Mainly because i am tired of turning the truck off put the parking back on and turning the truck back on just so the lights dont come on when you are in a parking lot at a townhouse waiting. What would not let me change to an 00 - 02 BCM module???
Originally Posted by dogger
jay if you push the dome light over ride four time's it'll over rid automatic head light's until you turn it off agian. might be another option for ya
You could swap out for the '02 pcm but you'll have to do a crank relearn. I heard they are better for tuning anyway; but I don't know if it would have anything to do with the dome override switch. You could just push the e-brake one notch, that'll make the light go off but isn't enough to actually engage the e-brake.
I also considered swapping in a newer BCM for the same reason, I would think that it can be done, but it may require a reflash by a dealer to work. I took the easy way out and wired an LED in place of the photodiode, making my headlights fully manual. Did it right at the BCM under the driver's side dash. Cost less than $2 and took about 5 minutes...having full control over your headlights.....priceless
Jay's asking about the BCM (Body Control Module), which is separate from the PCM (Powertrain Control Module)...but you are correct, the 02 PCM is a nice upgrade for a 99-00 for tuning purposes.
Originally Posted by duwem
led, fully manual, huh?
Here's a schematic for anyone who needs it:
